Sun Nov 03, 2019 6:13 am
Umtauscher offline
That was my first thought also.
So I reset one Thermostat and included it as a new device to no avail.
I think, if you included them in 7.3 they will not be changed during the update...
Sun Nov 03, 2019 6:23 am
So is it just a new Spirit that you are adding to 7.4?
Do any existing (pre Indigo 7.4) Spirits show OK in Indigo 7.4?
If a new Spirit, maybe the model Id has changed in which case Indigo probably won't know about it but should be relatively easy to fix. You can dump the device details to the log and share here so it can be checked out (if that is the issue). :)
Sun Nov 03, 2019 6:50 am
Umtauscher offline
Its not my setup, it‘s a new device from on e of my neighbours.
He asked me yesterday about the setup of the thermostats and thatˋs when I found out.
    Z-Wave                          Indigo Device "046 - Thermostat" Z-Wave Properties:
Indigo Z-Wave Version: 7.4.0
Node ID: 46
Model: General Thermostat (v2)
Model ID: 00020015
Manufacturer: Aeon Labs
Manufacturer ID: 0371
Protocol Version: 4.61
Application Version: 0.16
Model Definition Version: 0
Library Type: 3
Class Name: General Thermostat (v2)
Class Hierarchy: 04 : 08 : 06
Command Class Base: 40
Command Versions: 40v1 80v1 43v1 85v1 86v1 55v1 98v1 59v1 5Av1 5Ev1 9Fv1 20v1 26v1 31v5 6Cv1 70v1 71v1 72v1 73v1 75v1 7Av1
Features: routing, battery, beaming, security, frequentWaking
Neighbors: 7, 13, 14, 17, 21, 29, 38, 41, 42, 43
Associations: 1:[1]
Config Values: - none -
here is one of mine included with 7.3 ( please ignore this one, the the corrected on is in the next post)
 Node ID: 159
Model: Thermostat (Spirit)
Model ID: 00030001
Manufacturer: EUROtronic
Manufacturer ID: 0148
Application Version: 0.15
Model Definition Version: 2
Library Type: 3
Neighbors: 3, 4, 58, 60, 61, 62, 74, 78, 80, 103, 122, 131, 133, 155
Associations: 1:[1]
Config Values: 1:0 2:0 3:1 5:5 6:2 8:0
If is really the device, it‘s very confusing that Euronic sells the same thermostats with the same firmware revision with different manufacturer info - but maybe that is the problem...
Sun Nov 03, 2019 6:55 am
Umtauscher offline
sorry I posed one of my thermostats with a different firmware version.
This is the one with the identical firmware version
   Z-Wave                          Indigo Device "Thermostat Studio rechts" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.124
Node ID: 150
Model ID: 00030001
Library Type: 3
Neighbors: 12, 27, 28, 39, 54, 56, 57, 58, 59, 60, 61, 62, 74, 86, 97, 122, 131
Associations: 1:[1]
Config Values: 1:0 2:0 3:1 5:2 6:2 8:0
Sun Nov 03, 2019 7:05 am
Well it is definitely different which is why, I guess, Indigo doesn't recognise it.
The Manufacturer Aeon Labs seems odd?
I think this issue needs Matt's input. :)
Sun Nov 03, 2019 11:37 am
Model ID: 00020015
0x0371 is definitely Aeotec's manufacturer ID not EUTROtronic's. What specifically does the branding show on the thermostat itself (and the manual) for both the manufacturer and the model?
Sun Nov 03, 2019 12:37 pm
shapa offline
Any news on generic "thermostat v2" and "schedules programming/heating source enabling only"? :)
Sun Nov 03, 2019 1:01 pm
Umtauscher offline
Hi Matt,
this is the label on the thermostat.
Model: Spirit Z-Wave Plus
EUROtronic Technology GmbH
Südweg1, 36396 Steinau
And the Z-Wave Plus logo
The user manual states: Version 2018/11
Sun Nov 03, 2019 1:49 pm
Strange they are using the manufacture ID, but we'll update Indigo (in 7.4.1) to use the Spirit device definition for that manufacture + model ID combination.
Sun Nov 03, 2019 1:54 pm
Umtauscher offline
Thanks Matt.
I suppose they bought the firmware and forgot to change the IDs
Cheers
Wilhelm
Sun Nov 10, 2019 7:49 am
Busta999 offline
Autolog - just a heads up of a weird issue that has come up twice in 24 hrs.
Seen three more Odd incidents yesterday and the day before.
I do not not believe the TRV Plugin is at fault here for Case 1 or 2 - but Case 3 was weird and maybe as it was driving the issue.
Case 1:
On Friday came home to find the Heating had been on for 36 hours continuously.
Mainly due to a spare Bedroom named after my Granddaughter who visits the most. Molly.
Mollys TRV setting is set point 17C for three schedules throughout the day. Overridden by 'Guest Mode' when she is here which moves the set point to maintain higher temps for each schedule.
Despite the TRV and Radiator reporting Heat=On and Valve 100% and the TRV and SRT321 /HRT4 reporting a set point of 17C and actual temp of 14C, which triggered the Variable to invoke the Central Heating to turn on.
Also the heating was on continuously for 36 hours.
Restarting the TRV Plugin had no impact.
Removing the Batteries and reseating them in the TRV caused the valve to actually open and heat to start being delivered to the radiator.
Case 2:-
Left the house for three hours yesterday.
On return found the Lounge at 18C three degrees below target set point of 21C for the time we were away.
Again the TRV and Radiator reported Heat=On and Valve 100% but no heat going through the Radiator despite the Heating being on.
Again restarting the TRV Plugin had no impact, the radiator remained cold despite reporting Heat On and Valve at 100%.
Again removing and returning the Batteries into the TRV restored heat to the Radiator.
Case 3:-
Guest bedroom was reporting 21C with a set point of 17C with the Valve reporting 51%.
Only resolved after removing and replacing batteries.
Summary:-
In cases 1 and 2 TRV and Radiator was reporting everything was doing what it should be = just the Spirits were not actually doing what they appear to be reporting.
In Cases 1 and 2 TRV Devices were demanding heat - the heating/boiler was actually on as the uncontrolled radiators - Mainly Hallway and Master Ensuite were hot and had managed to get the rooms to 25C. I have graphs that captured all this.
It is possible that using rechargeable batteries may be the cause of this.
All Radiator TRVs were reporting Battery level at 30-35% - where Eneloop rechargeable batteries had been installed from March to June 2019.
I have replaced the batteries on ALL TRVs testing the new Ikea Ladda hybrid batteries along with a range of Eneloop Black and White pairs.
I have reset the alarm level on TRV batteries from 21% to 39% to replace them earlier.
I'll keep an eye on this - may setup some triggers to detect aberrant behaviour earlier in future.
Sun Nov 10, 2019 8:20 am
Thanks for the report. :)
If it happens again, can you check the status of the Spirit TRV device and see whether it's mode is OFF or HEAT.
Sun Nov 10, 2019 8:55 am
Busta999 offline
Raised this as an oddity - in case anyone else has encountered or if they do will be able to recognise so we can devise mitigation paths.
Both TRV (Spirit) and Radiator were reporting Heat=On
All looked good except the radiator and TRV (Spirit) devices were reporting 100% open with heating confirmed on and pumping but not hot water going through the radiator.
Its as if both times the actual TRV Spirit Radiator was reporting Heat On and valve 100% which the TRV Controller would see as it having done its job.
My suspicion is the actual Spirit device on the Radiator - and that may be caused by using rechargeable batteries.
I'll keep a closer eye on them, because while not advised, if the rechargeables could do the job, it would reduce financial and environmental costs.
Mon Nov 11, 2019 5:29 am
Umtauscher offline
I just wanted to report, that I have similar problems with some of my Spirits.
I have disabled the TRV controller, because for me it just is not the right strategy, so I can rule out any influences of that plugin.
So the incident was:
Two of my Spirits definately showed a different valve value than was actually set.
For example the setpoint was 22 and the actual temperature was 26. But the valve was still open. Removing the batteries and reinstalling them solved that discrepancy and closed the valve.
Battery level was 90% at that time. I don't remeber the valve value reported in Indigo. Next time something like this happens, I will record the actual numbers and report back.
Cheers
Wilhelm
Mon Nov 11, 2019 8:40 am
siclark offline
After seeing many of these similar issues myself when I started with these I haven't experienced any problems for months. All seem to be running as they should.
I have them set to turn off when not in use rather than just lower the SP which seems to have helped and hehe optimised zwave network to ensure commands get through
I also use rechargeable batteries without any issue, other than them running out faster than normal but just have to change them when I get my notification that they are at 20%.
Page 21 of 26 1 ... 18, 19, 20, 21, 22, 23, 24 ... 26
