Mon Oct 21, 2019 1:22 pm
shapa offline
1) Add one ")" at tthe end :)
I.e. Remote Stat Device:\n {}".format(indigo.devices[1834533522]))
2) Run it from a scripting console (plugins->open scripting shell)
Ksullivan wrote:
Hi John
The shell command doesnt seem to work as im getting a timed out :( Any ideas?
indigo.server.log(u"Remote Stat Device:\n {}".format(indigo.devices[1834533522])
2019-10-21 20:10:07.174 IndigoPluginHost[86035:1838786] ConnectionRequest() caught exception: ServerCommunicationError -- timeout waiting for server to start
2019-10-21 20:10:07.175 IndigoPluginHost[86035:1838767]
connection to server failed or was dropped
Tue Oct 22, 2019 10:13 am
Ksullivan wrote:
Hi John
oops - left a quote off - to fast with the cut & paste. :oops:
Tue Oct 22, 2019 10:15 am
shapa wrote:
Tried to set 32C - the same issue, resetting to 5C :)
Is it possible to add a setting to be able to switch on / off the setpoint logic? For a smart floor thermostat - only schedules (with setpoints) are required. TF021 will automatically do the rest. However, the logic could be very useful in case of a "dumb" relay controlling underfloor heating - so it would be nice to make it configurable.
OK - I will have to take a look at this - maybe take a few days now as grandson minding for the next couple of days. :)
Tue Oct 22, 2019 10:44 am
Ksullivan offline
Hi John
Sorry to be a pain but I couldn’t get the script to work it seemed not to talk to Indigo (even with the extra bracket) any ideas?
No hurry if you’re on child duties
Thank you
Keith
Tue Oct 22, 2019 11:40 am
Ksullivan wrote:
... I couldn’t get the script to work it seemed not to talk to Indigo (even with the extra bracket) any ideas? ...
My fault again - it needs yet another ) - so there should be two ) after the ]. :oops:
indigo.server.log(u"Remote Stat Device:\n {}".format(indigo.devices[1834533522]))
Tue Oct 22, 2019 1:21 pm
Ksullivan offline
That did it, heres the Stat details
Interactive Shell Remote Stat Device:
address :
batteryLevel : None
buttonGroupCount : 0
configured : True
coolIsOn : False
coolSetpoint : 0.0
dehumidifierIsOn : False
description :
deviceTypeId : simpleSmartThermostat
displayStateId : temperatureInputsAll
displayStateImageSel : HvacAutoMode
displayStateValRaw : 20.4
displayStateValUi : 20.4
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
fanIsOn : False
fanMode : Auto
folderId : 1877502068
com.odd-henrik.indigoplugin.smartdevices : (dict)
NumHumidityInputs : 0 (integer)
NumTemperatureInputs : 1 (integer)
SetPointVariable : 1848860431 (string)
ShowCoolHeatEquipmentStateUI : true (bool)
SupportsCoolSetpoint : false (bool)
SupportsHeatSetpoint : true (bool)
SupportsHvacFanMode : false (bool)
SupportsHvacOperationMode : true (bool)
acHeatPumpDevices : (string)
autoLabel21 : Test (string)
configTemperatureDelta : 0.3 (string)
floorTemperatureSensors : (string)
outsideTemperatureSensors : (string)
primaryHeaterDevices : (list)
Item : 1642299511 (string)
primaryTemperatureSensors : (list)
Item : 950621296 (string)
primaryTemperatureVariables : (list)
secondaryHeaterDevices : (string)
sensorInputOptions : 0 (string)
supportsStatusRequest : false (bool)
thermostatOffOptions : off (string)
thermostatOnOptions : heat (string)
useThermostatsAsPrimaryHeater : false (bool)
useVariableSetPoint : false (bool)
ventilationDevices : (string)
heatIsOn : False
heatSetpoint : 20.0
humidities : []
humiditySensorCount : 0
hvacMode : HeatCool
lastChanged : 2019-10-22 20:17:36
lastSuccessfulComm : 2019-10-22 20:17:36
model : Simple Smart Thermostat
name : Bedroom 1 Thermostat
ownerProps : com.odd-henrik.indigoplugin.smartdevices : (dict)
pluginId : com.odd-henrik.indigoplugin.smartdevices
protocol : Plugin
remoteDisplay : True
states : States : (dict)
hvacCoolerIsOn : off (on/off bool)
hvacDehumidifierIsOn : off (on/off bool)
hvacFanIsOn : off (on/off bool)
hvacHeaterIsOn : off (on/off bool)
hvacHumidifierIsOn : off (on/off bool)
hvacOperationMode : 3 (integer)
hvacOperationMode.ui : auto on (string)
hvacOperationModeIsAuto : true (bool)
hvacOperationModeIsCool : false (bool)
hvacOperationModeIsHeat : false (bool)
hvacOperationModeIsOff : false (bool)
hvacOperationModeIsProgramAuto : false (bool)
hvacOperationModeIsProgramCool : false (bool)
hvacOperationModeIsProgramHeat : false (bool)
setpointHeat : 20 (real)
setpointHeat.ui : SetP: 20.0° (string)
temperatureDelta : 0.3 (string)
temperatureInput1 : 20.4 (real)
temperatureInput1.ui : 20.4° (string)
temperatureInputsAll : 20.4 (string)
subModel :
supportsAllOff : False
supportsCoolSetpoint : False
supportsHeatSetpoint : True
supportsHvacFanMode : False
supportsHvacOperationMode : True
supportsStatusRequest : True
temperatureSensorCount : 1
temperatures : [20.4]
version : None
Tue Oct 22, 2019 2:01 pm
shapa offline
next couple of days
UK school holidays - my "toddler" is quite happy as well :))
Thu Oct 24, 2019 5:07 am
Ksullivan wrote:
That did it, heres the Stat details ...
Thanks for this. :)
Can you also do the same for the TRV Controller device that is controlling the Stella-Z?
Thanks. :)
Thu Oct 24, 2019 5:11 am
I could add that change to the request list. :wink:
Can you do a device print for the TRV Controller device that is controlling the HeatIT TF021? If possible, post the results in a code block so I get to see the indentations.
Thanks. :)
Thu Oct 24, 2019 1:13 pm
Ksullivan offline
Hi
TRV details
address : 13
batteryLevel : 20
configured : True
coolIsOn : False
coolSetpoint : 0.0
description :
deviceTypeId : trvController
displayStateImageSel : HvacHeatMode
displayStateValRaw : 20, 21
displayStateValUi : 20, 21
enabled : True
errorState :
fanIsOn : False
fanMode : Auto
com.autologplugin.indigoplugin.trvcontroller : (dict)
NumTemperatureInputs : 2 (integer)
SupportsBatteryLevel : true (bool)
address : 13 (string)
csvCreationMethod : 0 (string)
csvRetentionPeriodHours : 24 (string)
csvShortName : Bedroom 1 (string)
csvStandardMode : 1 (string)
enableTrvOnOff : false (bool)
heatingId : 0 (string)
heatingVarId : 0 (string)
hideTempBroadcast : true (bool)
pollingScheduleActive : 5 (string)
pollingScheduleInactive : 20 (string)
pollingSchedulesNotEnabled : 30 (string)
remoteDeltaMax : 2.5 (string)
remoteDevId : 1834533522 (string)
remoteSetpointHeatControl : true (bool)
remoteTempOffset : 0.0 (string)
remoteThermostatContolEnabled : true (bool)
schedule1Enabled : false (bool)
schedule1SetpointHeat : 21 (string)
schedule1TimeOff : 10:00 (string)
schedule1TimeOn : 07:00 (string)
schedule2Enabled : false (bool)
schedule2SetpointHeat : 20 (string)
schedule2TimeOff : 14:00 (string)
schedule2TimeOn : 12:00 (string)
schedule3Enabled : false (bool)
schedule3SetpointHeat : 21 (string)
schedule3TimeOff : 20:00 (string)
schedule3TimeOn : 17:00 (string)
schedule4Enabled : false (bool)
schedule4SetpointHeat : 22 (string)
schedule4TimeOff : 22:30 (string)
schedule4TimeOn : 22:00 (string)
setpointHeatDeviceStartDefault : 8.0 (string)
setpointHeatDeviceStartMethod : 1 (string)
setpointHeatMaximum : 28 (string)
setpointHeatMinimum : 6 (string)
setpointHeatOnDefault : 20 (string)
supportedModel : Thermostat (Stella Z) (string)
supportsHvacOnOff : false (bool)
supportsHvacOnOffHidden : false (bool)
supportsManualSetpoint : false (bool)
supportsTemperatureReporting : true (bool)
supportsValveControl : false (bool)
supportsWakeup : true (string)
trvDevId : 1186165993 (string)
valveAssistance : false (bool)
version : 1.2.0 (string)
heatIsOn : True
heatSetpoint : 20.5
humidities : []
hvacMode : Heat
lastChanged : 2019-10-24 20:09:17
lastSuccessfulComm : 2019-10-24 20:09:17
model : TRV Controller
name : Bedroom 1 TRV
ownerProps : com.autologplugin.indigoplugin.trvcontroller : (dict)
pluginId : com.autologplugin.indigoplugin.trvcontroller
protocol : Plugin
advanceActivatedTime : Inactive (string)
advanceActive : false (bool)
advanceStatusUi : (string)
advanceToScheduleTime : Inactive (string)
batteryLevel : 20 (integer)
batteryLevel.ui : 20% (string)
batteryLevelRemote : 0 (integer)
batteryLevelRemote.ui : 0% (string)
batteryLevelTrv : 20 (integer)
batteryLevelTrv.ui : 20% (string)
boostActive : false (bool)
boostDeltaT : 0 (real)
boostMinutes : 0 (integer)
boostMode : 3 (integer)
boostModeUi : (string)
boostSetpoint : 0 (integer)
boostStatusUi : (string)
boostTimeEnd : Inactive (string)
boostTimeStart : Inactive (string)
controllerMode : 2 (integer)
controllerModeUi : UI Control (string)
eventReceivedDateTimeRemote : 2019-10-24 20:09:17 (string)
extendActivatedTime : Inactive (string)
extendActive : false (bool)
extendLimitReached : false (bool)
extendMinutes : 0 (integer)
extendScheduleNewTime : Inactive (string)
extendScheduleOriginalTime : Inactive (string)
extendStatusUi : (string)
hvacHeaterIsOn : on (on/off bool)
hvacOperationMode : 1 (integer)
hvacOperationMode.ui : heat on (string)
hvacOperationModeIsAuto : false (bool)
hvacOperationModeIsHeat : true (bool)
hvacOperationModeTrv : 1 (integer)
nextScheduleExecutionTime : No schedules enabled (string)
schedule1Active : false (bool)
schedule1SetpointHeat : Not Set (string)
schedule1TimeOff : 00:00 (string)
schedule1TimeOn : 00:00 (string)
schedule1TimeUi : Inactive (string)
schedule2Active : false (bool)
schedule2SetpointHeat : Not Set (string)
schedule2TimeOff : 00:00 (string)
schedule2TimeOn : 00:00 (string)
schedule2TimeUi : Inactive (string)
schedule3Active : false (bool)
schedule3SetpointHeat : Not Set (string)
schedule3TimeOff : 00:00 (string)
schedule3TimeOn : 00:00 (string)
schedule3TimeUi : Inactive (string)
schedule4Active : false (bool)
schedule4SetpointHeat : Not Set (string)
schedule4TimeOff : 00:00 (string)
schedule4TimeOn : 00:00 (string)
schedule4TimeUi : Inactive (string)
setpointHeat : 20.5 (real)
setpointHeatMaximum : 28 (real)
setpointHeatMinimum : 6 (real)
setpointHeatOnDefault : 20 (real)
setpointHeatRemote : 20.5 (real)
setpointHeatTrv : 23 (real)
temperature : 20.2 (real)
temperatureInput1 : 20.2 (real)
temperatureInput1.ui : 20.2 °C (string)
temperatureInput2 : 21 (real)
temperatureInput2.ui : 21.0 °C (string)
temperatureInputsAll : 20, 21 (string)
temperatureRemote : 20.2 (real)
temperatureTrv : 21 (real)
temperatureUi : R: 20.2 °C, T: 21.0 °C (string)
valvePercentageOpen : 0 (integer)
zwaveEventReceivedDateTimeRemote : N/A (string)
zwaveEventReceivedDateTimeTrv : 2019-10-24 20:08:40 (string)
zwaveEventSentDateTimeRemote : N/A (string)
zwaveEventSentDateTimeTrv : 2019-10-24 20:08:31 (string)
subModel :
temperatureSensorCount : 2
temperatures : [20.0, 21.0]
version : 1.2.0
Thu Oct 24, 2019 1:39 pm
Ksullivan wrote:
Hi
TRV details ...
Thanks for the info - will try and take a more detailed look at this over the next couple of days. :)
Fri Oct 25, 2019 9:37 am
shapa offline
   Interactive Shell               TRV Device:
 address : 165
batteryLevel : 0
configured : True
coolIsOn : False
coolSetpoint : 0.0
description :
displayStateValRaw : 21.8
displayStateValUi : 21.8
enabled : True
errorState :
fanIsOn : False
fanMode : Auto
folderId : 1447924061
          address : 165 (string)
          csvShortName :  (string)
          hideTempBroadcast : false (bool)
          remoteDeltaMax : 5.0 (string)
          remoteDevId : 1820233887 (string)
          remoteSetpointHeatControl : false (bool)
          schedule1Enabled : true (bool)
          schedule2Enabled : true (bool)
          schedule3Enabled : true (bool)
          schedule4Enabled : true (bool)
          setpointHeatDeviceStartDefault : 21 (string)
          setpointHeatDeviceStartMethod : 3 (string)
          setpointHeatMaximum : 35 (string)
          setpointHeatMinimum : 5 (string)
          setpointHeatOnDefault : 21 (string)
          supportedModel : Thermostat (TF021) (string)
          supportsManualSetpoint : true (bool)
          supportsTemperatureReporting : false (bool)
          supportsWakeup : false (string)
          trvDevId : 830832617 (string)
          valveAssistance : true (bool)
          version : 1.3.7 (string)
heatIsOn : False
heatSetpoint : 5.0
humidities : []
hvacMode : Heat
lastChanged : 2019-10-25 16:36:26
lastSuccessfulComm : 2019-10-25 16:36:26
name : Conservatory Floor TRV HeatIT
protocol : Plugin
     batteryLevel : 0 (integer)
     batteryLevel.ui : 0% (string)
     batteryLevelTrv : 0 (integer)
     batteryLevelTrv.ui : 0% (string)
     controllerMode : 6 (integer)
     controllerModeUi : Remote UI Control (string)
     eventReceivedDateTimeRemote : N/A (string)
     nextScheduleExecutionTime : 17:00 (string)
     schedule1SetpointHeat : 21.0 °C (string)
     schedule1TimeUi : 07:00 - 10:00 (string)
     schedule2SetpointHeat : 20.0 °C (string)
     schedule2TimeUi : 12:00 - 14:00 (string)
     schedule3SetpointHeat : 21.0 °C (string)
     schedule3TimeUi : 17:00 - 20:00 (string)
     schedule4SetpointHeat : 22.0 °C (string)
     schedule4TimeUi : 22:00 - 22:30 (string)
     setpointHeat : 5 (real)
     setpointHeatMaximum : 35 (real)
     setpointHeatMinimum : 5 (real)
     setpointHeatOnDefault : 21 (real)
     setpointHeatRemote : 0 (integer)
     setpointHeatTrv : 5 (real)
     temperature : 21.8 (real)
     temperatureInput1 : 21.8 (real)
     temperatureInput1.ui : 21.8 °C (string)
     temperatureInputsAll : 21.8 (string)
     temperatureRemote : 21.8 (real)
     temperatureRemotePreOffset : 21.8 (real)
     temperatureTrv : 0 (real)
     temperatureUi : R: 21.8 °C (string)
     zwaveEventReceivedDateTimeTrv : N/A (string)
     zwaveEventSentDateTimeTrv : N/A (string)
subModel :
temperatures : [21.8]
version : 1.3.7
Sat Oct 26, 2019 8:25 am
Ksullivan offline
autolog wrote:
Ksullivan wrote:
Hi
TRV details ...
Hi
Please don’t bust a gut as I have now giggled things about that I use the TRV device as the thermostat and only use the thermostat to read the temperature ( unchecked the option to update from remote stat)
Things seem to behaving
Thank you
Sat Oct 26, 2019 8:37 am
Ksullivan wrote:
... I use the TRV device as the thermostat and only use the thermostat to read the temperature ( unchecked the option to update from remote stat).
Thanks for the update.
However, it should work so I will be taking a look at it in due course. :)
Sat Oct 26, 2019 8:38 am
@shapa thanks for the info. :)
Page 19 of 28 1 ... 16, 17, 18, 19, 20, 21, 22 ... 28
