superholz wrote:autolog wrote:superholz wrote:... Tried it and it does not seem to work. The setpoint set at the trv is not taken over by the TRV controller. Instead it seems that the old setpoint is lost and set to minimum temperature (4°C).
What is the custom state controllerModeUi set to after you do this?
Hi, sorry, my Z-wave network died and I had to rebuilt it... now picking up this point: where do i find this property? I have no property list at the device as sometimes seen here in screenshots.
Hi.... yes I found it .
When I change manually the temperature at the device the parameter variable changes from:
controllerModeUi = UI Control
controllerModeUi = TRV UI Control
I have some more issues/questions.
Some of the controlled thermostats show strange behavior. They almost t continuously open en close the valve. I think it has something to do with switching around the set point maybe does to the fact that the temperature measurement arbitrary gives values with small changes with trigger the valve(?). Any parameters I could set to improve it?
