Plugin does not work with Indigo 2021.1
Sat Jun 19, 2021 5:05 am
boekweg offline
Since I updated Indigo to version 2021.1 the Doorbird plugin does not work anymore. It is not possible to create a new doorbird device and the existing one is not available anymore.
Any solution for this?
The eventlog shows
Reloading plugin "DoorBird 1.0.0"
Starting plugin "DoorBird 1.0.0" (pid 43097)
DoorBird Error Error in plugin execution InitializeMain:
File "plugin.py", line 10, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/DoorBird.indigoPlugin/Contents/Server Plugin/pysodium/__init__.py", line 33, in <module>
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ctypes/__init__.py", line 444, in LoadLibrary
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ctypes/__init__.py", line 366, in __init__
OSError: dlopen(libsodium.dylib, 6): no suitable image found. Did find:
libsodium.dylib: mach-o, but wrong architecture
/Library/Application Support/Perceptive Automation/Indigo 2021.1/Plugins/DoorBird.indigoPlugin/Contents/Server Plugin/libsodium.dylib: mach-o, but wrong architecture
Stopping plugin "DoorBird 1.0.0" (pid 43097)
Stopped plugin "DoorBird 1.0.0"
Tue Jun 22, 2021 8:30 pm
Re: Plugin does not work with Indigo 2021.1
The libsodium.dylib library that is included with the plugin only supports Intel architecture but needs to support arm64 (M1) to be used with Indigo 2021.1.
You might be able to use Homebrew to install it on your Mac instead. Note if you do that you might have to delete this file out of the plugin so it finds the version homebrew installed instead:
(then restart the plugin)
Sat Jun 26, 2021 7:00 am
tazswe offline
Upgraded to 2021.1 and my DoorBird plugin worked without any problems.
Sat Jul 03, 2021 1:42 pm
boekweg offline
I guess it runs on a intel mac then? I have a M1 Mac Mini
Wed Jul 07, 2021 6:32 pm
rapamatic offline
This worked for me - "brew install libsodium" and then I needed to copy libsodium.23.dylib from /opt/homebrew/cellar/libsodium/.... into the plugin contents folder, and rename as libsodium.dylib. For some reason it didn't work just using an alias to that file, but not a big deal to copy it.
Wed Jul 07, 2021 6:56 pm
Great – thanks for the report.
Wed Jul 28, 2021 12:58 am
kwijibo007 offline
Apologies for missing this. I'm working out how to integrate the arm and intel version into the plugin.
Wed Jul 28, 2021 5:37 am
kwijibo007 offline
Version 1.1.0 of the plugin has been released and includes support for M1 Macs.
Pete
Wed Jul 28, 2021 3:01 pm
Awesome – thanks for the update Pete!
Mon Jul 11, 2022 2:44 pm
PvG offline
Hmm. I have an Intel MacMini and still get the above error with Indigo 2022.1.2 and Doorbird v1.2.0:
  File "plugin.py", line 22, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/DoorBird.indigoPlugin/Contents/Server Plugin/pysodium/__init__.py", line 33, in <module>
  File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ctypes/__init__.py", line 444, in LoadLibrary
  File "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ctypes/__init__.py", line 366, in __init__
   libsodium.dylib: code signature in (libsodium.dylib) not valid for use in process using Library Validation: library load disallowed by system policy
   /Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/DoorBird.indigoPlugin/Contents/Server Plugin/libsodium.dylib: code signature in (/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/DoorBird.indigoPlugin/Contents/Server Plugin/libsodium.dylib) not valid for use in process using Library Validation: library load disallowed by system policy
What am I doing wrong?
Tue Jul 12, 2022 8:48 am
Looks like macOS may have quarantined the plugin. Try executing this in a Terminal window:
sudo xattr -rd com.apple.quarantine /Library/Application\ Support/Perceptive\ Automation/Indigo\ 2022.1/Plugins
Sat Aug 06, 2022 6:23 am
PvG offline
That did the trick.
Sat Aug 13, 2022 2:52 am
berkinet offline
I am unable to install the 2.0.0 version and cannot go back to the previous version (1.2.0) either. In both cases I get an OS error
DoorBird.indigoPlugin” cannot be opened because the developer cannot be verified.
macOS cannot verify that this app is free from malware.
and I then get the following in the Indigo log (which makes sense since the install failed.)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/ctypes/__init__.py", line 452, in LoadLibrary
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/ctypes/__init__.py", line 374, in __init__
type: dlopen(libsodium.dylib, 0x0006): tried: '/Library/Application Support/Perceptive Automation/Indigo 2022.1/IndigoPluginHost3.app/Contents/MacOS/../Frameworks/libsodium.dylib' (no such file), 'libsodium.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64h')), '/usr/lib/libsodium.dylib' (no such file), '/Library/Application Support/Perceptive Automation/Indigo 2022.1/Plugins/DoorBird.indigoPlugin/Contents/Server Plugin/libsodium.dylib' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64h'))
Intel Mac,
MacOS 12.5
Indigo 2022.1
I have run the quarantine related command noted by Jay
I have updated other plugins without having this problem.
Sat Aug 13, 2022 2:56 pm
kwijibo007 offline
This occurs because I include the binary files for libsodium which is used for reading the encrypted DoorBird messages.
The binary files have to be compiled manually. As this is fairly complicated to do I’ve included them in the plug-in but it causes the OS to quarantine them (sometimes).
I’ve never used Jay’s fix. I go into MacOS settings and Security. Within there is a message saying the plug-in was blocked. There you can unblock It. Then restart the plug-in.
Sun Aug 14, 2022 8:22 am
berkinet offline
kwijibo007 wrote:
...go into MacOS settings and Security. Within there is a message saying the plug-in was blocked. There you can unblock It. Then restart the plug-in.
Thanks. The timing is a bit tight. I had to have the Security pane open and then start the install, have it send the first fail message, say Ok. Let it complete, then restart it in Indigo, and again say Ok. But, it is running again.
