Error - Unable to decode data
Mon Apr 08, 2019 1:26 pm
Colly offline
Hi Dave,
Been getting the following error for the last few days, any suggestions? No intentional changes on my behalf that I'm aware of.
   Fantastic Weather Error         Unable to decode data. (Line 843) No JSON object could be decoded
TIA
Mon Apr 08, 2019 1:36 pm
Colly offline
Re: Error - Unable to decode data
Nothing like solving your own problems :?
Having restarted Indigo (for another reason) earlier the error was still there however reloading the plugin seems to have resolved for now. I'll monitor and report back later...
Mon Apr 08, 2019 2:05 pm
Colly offline
Update: Problem resurfaced shortly after my post. I then realised I wasn't on the latest version so upgraded and now have the following in log. Hope this helps narrow the issue down.
   Fantastic Weather Error         Problem parsing Weather data. Dev: Daily Forecast (Line: 1763 Error: 403 Client Error: Forbidden for url: https://api.darksky.net/forecast/?exclude=%22minutely%22&extend=%22%22&units=auto&lang=en)
   Fantastic Weather Error         Problem parsing Weather data. Dev: Hourly Forecast (Line: 1763 Error: 403 Client Error: Forbidden for url: https://api.darksky.net/forecast/,-6.2488899231?exclude=%22minutely%22&extend=%22%22&units=auto&lang=en)
   Fantastic Weather Error         Problem parsing Weather data. Dev: New Weather (Line: 1763 Error: 403 Client Error: Forbidden for url: https://api.darksky.net/forecast/,-6.2488899231?exclude=%22minutely%22&extend=%22%22&units=auto&lang=en)
Mon Apr 08, 2019 4:08 pm
Sorry to hear that you're having trouble. You probably want to edit your post above to take your API key out of the log data.
Let me do some leg work and I'll get back to you.
Mon Apr 08, 2019 4:11 pm
I tried one of your URLs in Safari, and got a daily usage limit exceeded response. You'll have to wait until midnight UTC for the API call counter to reset, but in the interim, I'd suggest revising downward the call limit in the plugin configuration menu to something like 500 calls to ensure that you have some left over for testing.
We'll get you going.
Mon Apr 08, 2019 4:36 pm
Colly offline
Thanks Dave,
Edited the post to remove key :oops:
I'll change the limit as suggested.
Tue Apr 09, 2019 5:37 am
Hi Colly - I tried your API key this morning (in Safari) and the data popped right up. Are you still getting the error message?
Tue Apr 09, 2019 11:42 am
Colly offline
Dave,
All good today. I’ll keep an eye on it over the next while. Thanks for checking it out.
Tue Apr 09, 2019 12:09 pm
Thanks for letting me know. If you see anything like this again, please check the plugin log to see if that can provide any more insight into what the source of the problem might be.
Tue Apr 09, 2019 12:10 pm
Colly offline
Will do.
