Fantastic Weather Feature Requests
Wed Jul 04, 2018 1:21 pm
Please post any feature requests to this thread.
Mon Jul 23, 2018 4:07 pm
Monstergerm offline
Re: Fantastic Weather Feature Requests
Plugin does not fill in any information in the Address field of the Indigo device list view.
It might be helpful to fill this field with the GPS coordinates of the device location (perhaps with 5 digit precision if this fits).
Mon Jul 23, 2018 6:14 pm
Thanks for the suggestion.
That's an easy field to populate. To be sure I understand, you mean five digits to the right of the decimal, right? [12.34567, 12.34567]
Mon Jul 23, 2018 6:53 pm
Monstergerm offline
Yes, 5 digits to the right of decimal point otherwise latitude and longitude is not accurate enough
Mon Jul 23, 2018 7:01 pm
Oh, yeah -- one thing doesn't affect the other. You can set the device lat/long to any accuracy you like (Dark Sky may round it at some level) -- whatever we display in the Indigo UI will be merely informational.
Tue Jul 24, 2018 1:38 pm
Monstergerm offline
some ideas ...
In the Hourly device, I believe the hour 1, hour 2 etc are always displayed in 24 hr format. Would it make sense to add an option to use 12 hr format with am/pm?
Further, it looks like Dark Sky throughout its data feed always use long names for wind directions (e.g. westsouthwest). On my control pages I often don't have enough room and prefer the shorter WSW. Could this be added as an option?
It might be useful to have the daily summary captured for the Hourly device:
"hourly":{"summary":"Partly cloudy starting this evening, continuing until tomorrow morning."
And it might be useful to have the weekly summary captured for the 8-Day device:
"daily":{"summary":"No precipitation throughout the week, with high temperatures falling to 84°F on Sunday."
Tue Jul 24, 2018 4:03 pm
Monstergerm wrote:
some ideas ...
Thanks for the great ideas.
This is a bug. Or maybe the better term is oversight. There is a setting for time format in the plugin configuration dialog, but it doesn't currently adjust the Hourly device time, and it should. I'll add that to the list.
Actually, they provide wind bearing in degrees and I convert that to long wind names. I can easily add a setting for long or short wind names. Added to the list.
Both easy adds. I'll do those too.
Thanks again. I really do appreciate the ideas you share and the help you've given me with testing.
Sat Jul 28, 2018 12:34 pm
roquej offline
First, thank you for the plug-in. Love it!
Second, a quick question. Why is it that non-of the weather plug-ins have a running weekly or 3-5 days precipitation count? This would be very useful in determining when to water plants.
Again, thank you!
JP
Sun Jul 29, 2018 5:11 am
Glad to hear that you're enjoying the plugin.
I hear you on rain. Dark Sky doesn't present any precipitation actuals-that's probably one of the biggest losses over WU. I'm still using WU7 for precip actual, and am thinking about getting something to measure rain locally.
Thu Jan 17, 2019 9:22 am
sumocomputers offline
Dave,
I have been using the FW plugin, and really like it, so thank you for your work on this.
I have also tinkered with the Dark Sky API directly, and I really like the "Currently" and "Minutely" data.
Are there are any plans to add these to FW?
And also the ability to call the API more often than every 5 minutes? If FW is the only app being used to call the Dark Sky API, even every 3 minutes only equates to 480 calls in 24 hours.
Chris
Thu Jan 17, 2019 12:56 pm
Hi Chris - glad that you're finding the plugin useful and thanks so much for the ideas.
I have already added additional refresh frequencies to the current build (under development) and those will be available in the next release. I chose to add 2, 3, and 4 minute intervals (1 minute would be 1,440 calls and be over the base API limit). I originally chose 5 minutes as the minimum because I didn't think that the weather data would change appreciably in smaller frequencies. No matter, it is now up to each user to decide for themselves. :D
The Weather device type gets its data from the API's 'currently' data set, so we're covered there.
With respect to the 'minutely' data, I have no plans to add it (AFAIK, you're the first person to request it). I will add your request to the feature requests list.
Cheers,
Dave
Mon May 13, 2019 9:12 am
norcoscia offline
How about a new hourly forecast page - something like this?
_______
Norm
Mon May 13, 2019 10:14 am
Hi Norm - this is something that would be pretty tough to do given that there are so many different screen sizes and resolutions to contend with. It would be pretty easy for you to do in the Control Page editor; however. Build one line and then copy/paste that line as many times as you want. Then, all you would need to do is update each control page element for the proper day/data.
Mon May 13, 2019 10:21 am
norcoscia offline
Thanks Dave good idea!!!!!
_______
Norm
