Fantastic Weather Plugin Bug Reports
Fri Jun 18, 2021 2:18 pm
Re: Fantastic Weather Plugin Bug Reports
Hello all - that should be an easy fix. I'll get a fix out asap.
Fri Jun 18, 2021 2:52 pm
I have pushed a fix to the Indigo Plugin Store. Version 1.0.13 should take care of the OS version bug.
Fri Jun 18, 2021 9:01 pm
Why did that give an error on 2021.1, and not on 7.5? The 11.4 value should have given an error on either version.
Sat Jun 19, 2021 5:31 am
Agreed. I'm not sure TBH. I was counting versions of OS 10.x (only evaluating the minor version). As soon as it went to 11.x, it should've thrown the warning.
I'm now comparing the entire version number (major and minor) so it should be good to go.
Sat Jun 19, 2021 6:18 am
Yeah, I need to make the same change in a couple plugins now. Should be able to get to it later today.
Sat Jun 19, 2021 10:26 am
cesarvog offline
Yes, I can confirm it works again.
Thanks for all your work!
Sat Jun 19, 2021 1:32 pm
Thanks for letting me know.
Sun Jun 20, 2021 9:34 am
zoff offline
When I try to install v1.0.13 it launches Indigo 7.5.
Sun Jun 20, 2021 9:42 am
Take a look at the suggestions on this forum thread to get Indigo 2021.1 to open (by default) your plugins.
Sun Jun 20, 2021 1:53 pm
zoff offline
Thanks! Just like every other file :?
Where's the face palm smilie...
Sun Jul 25, 2021 2:47 pm
Bildhauer offline
Asking the plugin to write the weather data to file the log shows:
Fantastic Weather Error         Error in plugin execution MenuAction:
  File "plugin.py", line 544, in dump_the_json
TypeError: Required argument 'format' (pos 1) not found
Sun Jul 25, 2021 4:11 pm
So it does! Thanks for the bug report. I'll take a look and see what I can find.
Sun Jul 25, 2021 4:55 pm
I've posted a fix for this bug to the GitHub releases page and will update the Indigo plugin store as soon as I can. In the meantime, you can use the version here:
https://github.com/DaveL17/Fantastic-Weather/releases/tag/1.0.15
In order for you to be able to write data to file, you'll need to wait for (or force) a refresh of the weather data after installing the update.
Tue Jul 27, 2021 4:45 am
The latest version of the plugin (1.0.17) is now available in the Indigo Plugin Store. This version includes all recent changes -- including fixes for known bugs. Users that currently using versions 1.0.15 or 1.0.16 do not need to update to v1.0.17.
Sat Apr 01, 2023 6:41 am
ryanbuckner offline
Lots of errors today:
Apr 1, 2023 at 8:32:02 AM
   Fantastic Weather Error         Unable to decode data.
  File "plugin.py", line 994, in get_weather_data
    parsed_json = json.loads(json_string)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/json/__init__.py", line 346, in loads
    return _default_decoder.decode(s)
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/json/decoder.py", line 337, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/json/decoder.py", line 355, in raw_decode
    raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 2 column 1 (char 1)
   Fantastic Weather Warning       Fantastic Weather - Daily cannot determine age of data. Skipping until next scheduled  poll.
   Fantastic Weather Warning       Fantastic Weather - Hourly cannot determine age of data. Skipping until next scheduled  poll.
