Fantastic Weather Plugin Updates
Thu Jul 26, 2018 7:46 am
Fantastic Weather Beta 4 has been released.
v0.1.04 (beta 4)
  • Adds "Daily Summary" state to daily weather devices.
  • Adds "Hourly Summary" state to hourly weather devices.
  • Adds plugin configuration option for Long vs. Short wind names.
  • Adds lat/long to Indigo UI Address field for most plugin devices.
  • Fixes bug where global time setting didn't affect Hourly device state UI [h##_hour].
v0.1.03 (beta 3)
  • Renames menu items from "Dark Sky" to "Fantastic Weather".
  • Updates support URLs to forum and wiki.
  • Improves device config dialog UI.
  • Fixed bug in setting of Weather Device dewpoint value.
  • Fixes bug in icon naming convention.
You can download the latest release here.
You can view the plugin documentation here.
Sat Aug 18, 2018 5:49 am
Re: Fantastic Weather Plugin Updates
Fantastic Weather Beta 5 has been released.
  • Adds 'Epoch' state to Hourly forecast device.
Fri Oct 05, 2018 6:27 am
Fantastic Weather Beta 6 has been released.
  • Adds additional traps when Dark Sky API is offline.
  • Fixes bug where alertCount state for weather devices was not resetting after severe weather alerts lifted.
Mon Oct 22, 2018 6:47 pm
Fantastic Weather Beta 7 has been released.
  • Adds forecast total precipitation state to daily weather devices.
  • Adds timezone setting to astronomy, daily, hourly and weather forecast devices.
  • Adds 'WindString' state to Weather devices -- i.e., 'East at 4.0 mph'.
  • Adds temperatures to Indigo device state list for Daily and Hourly Weather devices (modified by temperature display units).
    • Daily reports daily High/Low (i.e., 72°/32°)
    • Hourly reports hourly High (i.e., 72°)
Explanations:
A few of these new features bear some explanation.
Forecast Total Precipitation State:
A new state added to daily weather devices. It is a derived value from taking the average hourly precipitation intensity and multiplying it by 24 hours. This is the total predicted precipitation for the day.
Timezone Setting:
Perhaps not the most appropriately named device setting to display times in either local timezone (the Indigo server timezone) or the location timezone (the geographic timezone of the location being monitored). This setting does not affect certain values--for example, if a weather alert text value says that a warning expires at 10 AM, that's 10 AM *in that location* and will not be modified by the plugin. This setting defaults to the Indigo server timezone and it *should* account for time weirdness (like daylight savings time). The following device states are always displayed in the Indigo Server timezone:
  • currentObservation
  • currentObservation24hr
  • currentObservationEpoch
Local timezone setting (US Central Time)
Screen Shot 2018-10-22 at 7.32.06 PM.png (25.99 KiB) Viewed 395 times
Location timezone setting (US Eastern Time)
Screen Shot 2018-10-22 at 7.32.21 PM.png (26.55 KiB) Viewed 395 times
Indigo Item List Values:
Adds temperature values to the Indigo device list for hourly and daily devices like this:
Screen Shot 2018-10-22 at 7.12.27 PM.png (25.9 KiB) Viewed 395 times
A big shout out to forum user Monstergerm for ideas and regression testing support.
Sun Oct 28, 2018 7:53 pm
Fantastic Weather Beta 8 has been released.
  • Fixes bug for latitude/longitude where default values could not be overridden.
  • Refinements to daily forecast email:
    • Adds long range forecast
    • Rounds total precipitation to 2 decimal places.
    • Refines data formatting.
    • Fixes bug for instances where email sent flag not reset on new day.
  • Hides development fields for icon names in plugin configuration dialog.
Tue Oct 30, 2018 6:33 pm
Fantastic Weather Beta 9 has been released.
  • Fixes a bug in getDeviceConfigUiValues: AttributeError: 'float' object has no attribute 'keys'.
Thu Nov 08, 2018 5:26 am
Fantastic Weather Beta 10 has been released.
  • Adds configuration option for hourly device UI display value.
    Options: Forecast high temperature [current hour | next hour].
  • Fixes typo in trigger names for hourly devices.
Within the configuration dialog for hourly weather devices, you can change the value that will appear in the Indigo device list. You can choose to show the forecast high temperature for the current hour (the one you're in) or the next hour (hourly forecast data points begin at :00 of the specified hour.)
Screen Shot 2018-11-08 at 5.25.34 AM.png (119.17 KiB) Viewed 259 times
This release combines the prior release into Beta 10 (last release changed to Beta 9).
Fri Nov 30, 2018 9:11 pm
Fantastic Weather Bug Fix for Beta 10 has been released.
If you receive the following error when trying to enable a Fantastic Weather Trigger, v0.2.02 should fix the problem.
  File "/Library/Application Support/Perceptive Automation/Indigo 7.2/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 1238, in triggerCreated
  File "plugin.py", line 358, in triggerStartProcessing
KeyError: key listOfDevices not found in dict
Thu Jan 03, 2019 9:21 pm
Fantastic Weather Beta 11 has been released.
  • Pretty prints severe weather alert text when written to the Indigo Events log.
  • Improves robustness when connection problems occur.
  • Removes plugin update notifications.
  • Reduces plugin debug logging considerably.
