Setting up the plugin
Sun Apr 19, 2020 3:41 pm
Re: Setting up the plugin
Thanks, I’ll compare to docs tomorrow.
Mon Apr 20, 2020 2:36 pm
Have a go with https://github.com/howartp84/SomfyManag ... /tag/1.0.5
As well as changing the descriptions in the device editor, i'm attempting to parse the JSON response to see if it succeeded or failed.
Let me know what debug log says.
Peter
Mon Apr 20, 2020 5:25 pm
rgspb offline
Here's what I got: (the shade did lower as expected but I see an error below)
Action Group Master Bath Shade Favorite
Somfy Manager Debug myLinkCmdSingle action called:
Somfy Manager Debug Target device: CC1049A9.4
Somfy Manager Sending payload: { "id":727, "method": "mylink.move.stop", "params": { "auth": "bayfront", "targetID" : "CC1049A9.4"} }
Somfy Manager Error Error in plugin execution ExecuteAction:
File "plugin.py", line 135, in myLinkCmdSingle
NameError: global name 'json_loads' is not defined
Sat May 02, 2020 2:56 pm
Thu Sep 17, 2020 8:28 am
webdeck offline
I've started seeing these errors with 1.0.6:
2020-09-16 06:52:35.425 Schedule        Lower Game Room Shade at Sunrise
2020-09-16 06:52:35.425 Action Group    Game Room Shade Down
]2020-09-16 06:52:35.426 Somfy Manager   Sending payload:  { "id":614, "method": "mylink.move.down", "params": { "auth": "REDACTED", "targetID" : "REDACTED"} }
2020-09-16 06:52:35.433 Somfy Manager Error     Error in plugin execution ExecuteAction:
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/__init__.py", line 339, in loads
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/json/decoder.py", line 367, in decode
ValueError: Extra data: line 1 column 37 - line 1 column 10621 (char 36 - 10620)
2020-09-16 06:52:40.423 Schedule        Lower Game Room Shade at Sunrise (delayed action)
2020-09-16 06:52:40.427 Somfy Manager   Sending payload:  { "id":693, "method": "mylink.move.down", "params": { "auth": "REDACTED", "targetID" : "REDACTED"} }
2020-09-16 06:52:40.427 Somfy Manager Error     Error in plugin execution ExecuteAction:
  File "plugin.py", line 153, in myLinkCmdSingle
NameError: global name 'reply' is not defined
Mon Dec 28, 2020 2:42 am
koensayr offline
Any luck here @webdeck?
Mon Dec 28, 2020 11:38 am
webdeck offline
I wound up rewriting the plugin and making it more reliable for my setup. Here is my updated version of plugin.py - Rename it to plugin.py and place it in the directory
$HOME/Perceptive Automation/Indigo 7.5/Plugins/SomfyManager.indigoPlugin/Contents/Server Plugin
Note that I am not the original author of the SomfyManager plugin.
plugin.py.txt
(6.21 KiB) Downloaded 3 times
Fri Jan 01, 2021 1:31 pm
Apologies, never saw the original question .
Will have a look.
