Thanks, I’ll take a look.
Somfy MyLink IP Address: The IP address of the MyLink hub (Can be found in the integration report in the Somfy App)
Somfy Mylink Port: Ensure this is set to 44100 if you are not sure
Somfy Mylink System ID: The System ID configured in the Somfy App (Can be found in the integration report in the Somfy App)
Device 1-5 Name: The human-readable name of the device you are adding
Device 1-5 ID: The Somfy targetID of the device you are adding (Can be found in the integration report in the Somfy App)
