Feature Requests
Thu Apr 26, 2018 2:23 am
Feature Requests
Could you also add in sunrise and sunset times? Then I can ditch a couple more variables for control pages :)
Sun Apr 29, 2018 1:50 am
srkinard offline
Re: Feature Requests
Dude...perfect timing on this!
My little 2011 mac mini running Indigo has been using a lot of CPU time lately. I have 8 tablets running various control pages throughout the house and I had put a clock display in the lower corner of each one. The only way I had gotten that to work was a scheduled task to insert timestamp into a variable, then have that variable displayed on the control pages for a clock.
This action definitely had an impact running every minute...using this plugin removed the need to do this and has helped bring the CPU use down alongside some other tweaks.
As far as a feature request, a few more date variations? like
Sun, Apr 29, 2018
Sunday, April 29
etc..
Ross
Sun Apr 29, 2018 1:53 am
I’m going to look into providing each date item separately, then see how best for users to join the states together how they want, such as the examples you gave.
Sun Apr 29, 2018 1:58 am
In fact I’ve just thought how to do it.
I’ll provide mechanism for users add custom states using the python date format, which I’ll then refresh for you same as the others, all in one place.
Peter
Mon Apr 30, 2018 9:37 am
Really? An Insert Timestamp into Variable action running once a minute should have had no impact on performance. Once a second, perhaps, but not once a minute.
Mon Apr 30, 2018 9:39 am
I did wonder, as presumably my plugin is doing as much in one minute as your action, in fact more as I’m inserting timestamp into several states every minute. (Not date, I only update those daily)
Mon Apr 30, 2018 3:39 pm
See announcement thread for update 1.0.4.
Tue May 01, 2018 1:13 am
srkinard offline
Well...seems the server still gets taxed...it takes time for things to ramp up after a restart. I think I'm going to just migrate it to the main 2010 Mac Pro again. Even with all the items running on that box, the CPUs are barely running a 7-10% average over time with occasional spikes to 30% or so when multiple people stream from Plex.
I'm gonna upgrade the 6c/12t Mac Pro CPUs from 2.4GHz E5645s in there now to a pair of X5690s running 3.46GHz soon...so the spikes should be shorter. As much as I'd like to justify buying a new 5K iMac, I don't actually need it...it's nothing more than an "I want" scenario.. Probably gonna upgrade the Mac Pro with a PCIe card + NVMe 1TB SSD to I can get much faster response from all services on it.
DIdn't mean to derail the Feature Request thread with tech weirdness...
Thanks again for the plugin Peter!
Sun Jun 10, 2018 2:20 pm
Done.
See 1.0.5
Sun Jun 10, 2018 5:18 pm
Cool! Thanks!
Sat Jun 23, 2018 1:59 pm
ckeyes888 offline
Nit picky I’m sure but how about a space between the time and am pm?
10:00am would display 10:00 am.
Carl
Sun Jun 24, 2018 8:06 am
ckeyes888 wrote:
How about a space between the time and am pm?
You can do this with the five custom formats.
%I:%M %p 09:00 am
%-I:%M %p 9:00 am
Sun Jun 24, 2018 2:35 pm
ckeyes888 offline
Sorry but I'm not sure how to implement this.
I copy and pasted this: %-I:%M %p into Custom 1
and set a trigger to fire on any change to Custom 1 to set my time variable but it doesn't work.
Must have missed something?
Carl
Sun Jun 24, 2018 2:42 pm
ckeyes888 offline
Getting closer. I set the trigger to fire on a change to local time and that works but the am pm is now in upper case.
Can it be in lower case?
Carl
If you just display the state Custom1 on a control page (or look in the UI states), it should show correctly?
I’m not at pc at moment to get screenshots.
