Trigger values
Mon Apr 23, 2018 4:59 am
Gusten offline
Trigger values
Hi
Thanx for a realy nice update on the Tesla Plugin
Before i used the Tesla Plugin to activate things in the car and i used an Tesla Script to collect status in Variables
I am now trying to convert all to your plugin
But for example, i have one trigger, that triggers if variable inside_temp is higher than 18 degreas
When trying to use the device state inside_temp i cant trigger on "Higher then"
See attached images
Is there any fix for this?
/Thanx Martin
tesle variable.JPG (52.66 KiB) Viewed 1894 times
tesle device.JPG (44.29 KiB) Viewed 1894 times
Mon Apr 23, 2018 6:28 am
Re: Trigger values
Ah, that’s because I create all data states as strings for simplicity. :(
I’ll a) re-look at this, and b) add triggers anyway.
Peter
Tue Apr 24, 2018 1:14 pm
Gusten offline
Re: Trigger values
Peter
Thanx :)
Sun Jun 10, 2018 5:22 pm
Re: Trigger values
Have a look at 1.0.8 Beta on https://github.com/howartp84/TeslaControlBETA/releases
You will need to recreate your device - I suggest you create a new device and just pick the same car, then when you're ready you can switch your actions/control panels etc over to use the new device.
Only the new device will allow the numerical comparisons.
Peter
Tue Jun 26, 2018 5:53 am
Gusten offline
Re: Trigger values
Hi Thank you, just tried the Beta 1.08 and i can see many of the values is possible to chose greater then, but not "inside temp" thats the one a am using.
I had to reset my Tesla Password, it had been "blocked" but if you need it again, let me know
Thanx Martin
Thu Jun 28, 2018 11:27 am
Re: Trigger values
I'll have a look; I currently evaluate if the initial value is numeric or not, then make it a string or numeric state accordingly.
Fri Jun 29, 2018 3:54 pm
Re: Trigger values
PM me your username/password - I'm not currently seeing an inside_temp state to look at.
Peter
