Testing Tesla EV Control
Wed May 11, 2022 9:38 am
anupchavda offline
Hi
Seeing as the new version of Indigo was released and I saw a bit of work had been done on this plugin, I wanted to test what was available.
Plugin installed correctly :D
Able to create device "Tesla" :D
Able to enter my refresh token :D
Able to query the car :D :D :D
This is amazing!!
the issue I have is when I try to create a trigger (ie open charge flap) I get the following which I believe is a python error: Vehicle.command() takes 2 positional arguments but 3 were given
   Tesla EV Control                Tesla command charge_port_door_open for vehicle 149xxxxxxxx
   Tesla EV Control Error          Vehicle.command() takes 2 positional arguments but 3 were given
   Tesla EV Control Error          Error issuing command: charge_port_door_open com.howartp.teslacontrol : (dict)
   Tesla EV Control Error          Plugin version: 3.0.1
   Tesla EV Control Debug          Traceback (most recent call last):
  File "plugin.py", line 226, in vehicleCommand
    self.response = vehicle.command(commandName, data)
TypeError: Vehicle.command() takes 2 positional arguments but 3 were given
Is this something I need to fix or I can help you with?
Wed May 11, 2022 9:46 am
anupchavda offline
Re: Testing Tesla EV Control
Further quick testing shows that the following commands work:
Wake
Get Charge State
Get Climate State
Get Drive State
Get Vehicle State
Get Vehicle Config
Get GUI State
Get Service Data State
The actual actions of getting something in the car to work (ie heaters, open charge port etc. etc) throw the above error message.
thanks
Wed May 11, 2022 9:57 am
anupchavda offline
sorry...me again.
Did some googling and came up with this...does this help??
https://www.codegrepper.com/code-exampl ... were+given
Wed May 11, 2022 11:44 am
Hi Anup
I'm going to have to play with this; I know why it's giving the error but I need to work out the right solution - i'm using a publicly available API so I'd rather fix my code to use theirs, than change theirs, in case they update it.
I never tested "commands" as the person whose car I have control of wasn't around so I couldn't start flashing his headlights or opening his boot for him! Querying values was safe enough to test!
What country/timezone are you in? Would you be happy to send me PM with your tesla account details (change password if you want) for a day or two?
Thu May 12, 2022 4:12 am
anupchavda offline
I'm in the same country as you (I think) as I'm down on London.
More than happy to get this access sorted for you so we can help the community.
I'll PM you.
Sat May 28, 2022 2:27 am
v3.0.2 is now published on the Plugin Store if anyone else gets this.
Mon May 30, 2022 6:13 pm
new2me07 offline
I'm getting these errors on 3.0.2
The only "physical" action that don't throw an error seem to be honk. I haven't methodically tested all actions.
May 30, 2022 at 8:03:44 PM
Tesla EV Control Tesla command DOOR_UNLOCK for vehicle 149xxxx
Tesla EV Control Error TeslaPy: Unknown endpoint name DOOR_UNLOCK
Tesla EV Control Error Error issuing command: DOOR_UNLOCK com.howartp.teslacontrol : (dict)
Tesla EV Control Error Plugin version: 3.0.2
May 30, 2022 at 8:04:21 PM
Action Group testiv
Tesla EV Control Tesla command DOOR_LOCK for vehicle 149xxxxx
Tesla EV Control Error TeslaPy: Unknown endpoint name DOOR_LOCK
Tesla EV Control Error Error issuing command: DOOR_LOCK com.howartp.teslacontrol : (dict)
