Cant find intense of WeatherSnoop
Posted:
Sun Jan 08, 2017 11:41 am
by clawmd
Trying to use the plugin without success. WeatherSnoop3 is running on the same computer as Indigo. It is pulling data from a local weather station and appears to function normally. When I try to add a WeatherSnoop device, there is nothing available in the "Select WeatherSnoop Instance" pull down and "scan for agents gets this:
Stopped plugin "WeatherSnoop 2.1.1"
Starting plugin "WeatherSnoop 2.1.1" (pid 35742)
Started plugin "WeatherSnoop 2.1.1"
WeatherSnoop Error No valid WeatherSnoop instance selected
Any idea what I am doing wrong?
Re: Cant find intense of WeatherSnoop
Posted:
Sun Jan 08, 2017 3:08 pm
by jay (support)
If it's not showing up in the list, then it's not finding it on the network. Given your other issue, I suspect you have something else going on thats causing some kind of network communication error that's causing anything using the network to fail. Is your network config non-standard in any way?
Posted:
Sun Jan 08, 2017 5:03 pm
by clawmd
Standard network with Comcast cable modem. A LinkSys router manages DHCP; all ip addresses are reserved. Port 8000 is passed through both to SecuritySpy. WeatherSnoop is on the same computer as Indigo, I am running the demo mode of WeatherSnoop. Weather snoop is pulling data from a published site and displaying all data correctly.
Posted:
Sun Jan 08, 2017 5:22 pm
by clawmd
Here is a log with debugging. I have securitySpy using port 8000. Is that the issue?
WeatherSnoop Debug stationSelected called
WeatherSnoop Debug server popup list: [('none', '- no weathersnoop servers available -')]
WeatherSnoop Debug getStateList targetId: 1276138589
WeatherSnoop Debug getStateList valuesDict: UiValuesDict : (dict)
address : (string)
displayState : none (string)
host : localhost (string)
label1 : (string)
lookForAgents : (string)
manual : false (bool)
port : 8000 (string)
sep1 : (string)
siteName : (string)
wsAgent : none (string)
wsInstance : none (string)
WeatherSnoop Debug getStateList siteFieldCache: {}
WeatherSnoop Debug getStateList itemList: [('none', '- no states available -')]
WeatherSnoop Debug scanForAgents called: UiValuesDict : (dict)
address : (string)
label1 : (string)
sep1 : (string)
siteName : (string)
Posted:
Sun Jan 08, 2017 6:05 pm
by matt (support)
Yes, you need to change so that each has a unique port.
Posted:
Sun Jan 08, 2017 6:42 pm
by clawmd
That did it! In the preferences panel for WeatherSnoop, you need to uncheck the box for "serve my data via HTTP.." , enter a different port, and recheck the box
