[SOLVED]Problems after WS 3.0.7 upgrade
Thu Apr 03, 2014 9:44 am
berkinet offline
It looks like the 3.0.7 upgrade added some new data elements. Since upgrading WS I am seeing the following in my Indigo log...
Apr 3, 2014, 08:38:00
Error device "1998 Weather Station" state key absoluteBarometricPressure_inHg not defined (ignoring update request)
Error device "1998 Weather Station" state key leafWetness3_inHg not defined (ignoring update request)
Error device "1998 Weather Station" state key leafWetness2_inHg not defined (ignoring update request)
Error device "1998 Weather Station" state key leafWetness1_inHg not defined (ignoring update request)
Error device "1998 Weather Station" state key leafWetness4_inHg not defined (ignoring update request)
Error device "1998 Weather Station" state key relativeBarometricPressure_inHg not defined (ignoring update request)
Error device "Weather-Mougins wug" state key relativeBarometricPressure_inHg not defined (ignoring update request)
Thu Apr 03, 2014 10:22 am
Re: Problems after WS 3.0.7 upgrade
I'll look into it.
Thu Apr 03, 2014 10:36 am
Did you try restarting the plugin?
Thu Apr 03, 2014 10:54 am
berkinet offline
Yes. No joy.
Thu Apr 03, 2014 2:33 pm
Yeah, I found the problem - the plugin isn't adding new fields correctly so I'll get that fixed.
Unfortunately, the real problem as I see it is that some existing API field names changed. This, of course, is going to break anything that's using the old field names (which we automatically translate into state keys). I've sent them an email and we'll see what the reply is.
Thu Apr 03, 2014 4:11 pm
Look for the fix in the next release (6.0.12) whenever that comes out. Drop me an email (indigo DASH support AT perceptiveautomation DOT com) if you want the fix before then.
Wed Apr 09, 2014 2:17 pm
wmcorbin offline
Re: [SOLVED]Problems after WS 3.0.7 upgrade
Wife can’t see status of various devices in Event Log because the WeatherSnoop errors over run the screen. If you have an early fix, I’d sure like to try it, too.
Wed Apr 09, 2014 4:00 pm
Send an email to indigo DASH support AT perceptiveautomation DOT com requesting the early release.
