[ANSWERED]Where to find WeatherSnoop "states" for scripts?
Sun Nov 17, 2013 10:25 am
gregjsmith offline
Where do I find these?
Sun Nov 17, 2013 10:54 am
Re: Where to find WeatherSnoop "states" for scripts?
In the Custom States tile in the control area. It'll be below the Device Details tile when you select your WeatherSnoop device so you'll either need to scroll the area or make it taller using the split view control between the list and control area.
Sun Nov 17, 2013 11:39 am
gregjsmith offline
Ah OK I found it. The device details window has some issue. It auto resizes itself which is annoying. Also I don't think the text is small enough.
Any chance of being able to break that out into a bigger window and the ability to copy and paste from it?
Sun Nov 17, 2013 6:55 pm
I'm not following - what auto resizes?
We've got a list of things to look at for the control area in a future release.
Sun Nov 17, 2013 8:26 pm
gregjsmith offline
It start off like this when I select Weather Station in the device list.
Then spontaneously shrink like this
Untitled 2.png (35.6 KiB) Viewed 3723 times
Sun Nov 17, 2013 9:18 pm
keifer1 offline
Played and found that if you resize window again it pops back full height again, It seems to revert to small window every 30 seconds.
Computer Keith
Mt Pleasant SC - Charleston
Indi-Go -Go-Go
Mon Nov 18, 2013 6:17 pm
What OS versions are you guys seeing this on?
Mon Nov 18, 2013 6:32 pm
gregjsmith offline
10.8.4
Mon Nov 18, 2013 10:55 pm
I've found the bug - should get it fixed in the next release.
Thu Dec 05, 2013 8:47 pm
berkinet offline
Did this get into 6.0.6? I didn't see it noted in the announcement.
Fri Dec 06, 2013 9:58 am
It should be - I believe we just forgot to get it into the change notes.
Fri Dec 06, 2013 11:50 am
berkinet offline
It should be - ...
It is. Thanks.
