Lightwave Repeater
Thu Mar 28, 2013 9:25 am
AndrewGWalsh offline
Lightwave Repeater
Has anyone else managed to get the Lightwave repeater working with the RFXTRX?
I've most of my Lightwave sockets working correctly now but the ones furthest from the transmitter won't pair and so I got the repeater to see whether that would help - but have had no luck setting it up.
Andrew
Fri Mar 29, 2013 7:35 am
Re: Lightwave Repeater
Right, I have it working. The important point was to set it up as an Appliance. :-)
Andrew
Fri Mar 29, 2013 8:46 am
Does the repeater work well? I was thinking of getting one for one of my furthermost away device that intermittently gets a poor signal.
Sat Mar 30, 2013 6:09 pm
It is certainly not working well - although it paired successfully and it worked for a day, it has since stopped. I have re-paired it, replaced the batteries and tried it in different places but it only works reliably for some sockets, not at all for others - all in the same room as the repeater.
I'm not giving up, shall keep you posted.
Andrew
