Update states and dim/brighten by %
Tue Nov 20, 2012 11:34 am
krissh offline
Hi!
I'm new to home automation, but have been experimenting with Indigo and RFXCOM for a week or so. I use Nexa wall switches and dimmers/appliances and have a couple of questions I hope some of you can help me with.
As I do not want to rely only on the mac being on and working, some of the wall switches are paired and controlling the dimmers directly. I've been trying to update the state of the devices in a trigger when a wall switch is used (to have correct state in e.g. control page). I've tried applescripts 'set on state of device ... to "On" ' and 'set state of device ... to "On" ' without success. I also tried updateStateOnServer with python, which was not permitted. How can I change the server on state for these devices?
Also, I've tried to use actions dim by % and brighten by % for a dedicated wall switch meant to increase/decrease brightness by 10% at each press. I get the following error in the log, am I doing something wrong? See also image of trigger action.
RFXCOM Error Error in plugin execution ExecuteAction:
File "plugin.py", line 147, in actionControlDimmerRelay
<type 'exceptions.TypeError'>: TurnBright() takes exactly 4 arguments (3 given)
Best regards
Kristian
Skjermbilde 2012-11-20 kl. 18.31.57.png (60.88 KiB) Viewed 2208 times
Tue Nov 20, 2012 3:35 pm
RJdeKok offline
Re: Update states and dim/brighten by %
Hi Krissh,
What kind of device is your stue downlights?
Can you make a screendump of its definition?
Tue Nov 20, 2012 4:16 pm
krissh offline
The device is set to AC Dimmer, it is a Nexa CMR-100 dimmer
Skjermbilde 2012-11-20 kl. 23.13.28.png (69.63 KiB) Viewed 2178 times
Mon Nov 26, 2012 1:43 pm
RJdeKok offline
I can't reproduce the problem. Are you sure you're using the latest version?
It's available here:http://www.rjdekok.nl/downloads/RFXCOM.indigoPlugin.zip
Mon Nov 26, 2012 6:16 pm
krissh offline
Thanks! It seems I did in fact have an older version, even though I downloaded from the user contribution library a few days ago. I reinstalled the plugin, and the error messages disappeared, although "dim by %" and "brighten by %" did not seem to work. I took the liberty of playing with your code, the following seems to work, at least for me.
For plugin.py I replaced
      ###### BRIGHTEN BY ######
      elif action.deviceAction == indigo.kDeviceAction.BrightenBy:
         if self.RFXTRX.TurnBright(action, dev, 0) == True:
            sendSuccess = True      # Set to False if it failed.
         newBrightness = dev.brightness + action.actionValue
         if newBrightness > 100:
            newBrightness = 100
         if sendSuccess:
            self.debugLog(u"sent \"%s\" %s to %d" % (dev.name, "brighten", newBrightness))
            dev.updateStateOnServer("brightnessLevel", newBrightness)
            self.debugLog(u"send \"%s\" %s to %d failed" % (dev.name, "brighten", newBrightness), isError=True)
      ###### DIM BY ######
      elif action.deviceAction == indigo.kDeviceAction.DimBy:
         if self.RFXTRX.TurnDim(action, dev) == True:
         newBrightness = dev.brightness - action.actionValue
         if newBrightness < 0:
            newBrightness = 0
         if sendSuccess:
            self.debugLog(u"sent \"%s\" %s to %d" % (dev.name, "dim", newBrightness))
            indigo.server.log(u"send \"%s\" %s to %d failed" % (dev.name, "dim", newBrightness), isError=True)
with
         #if self.RFXTRX.TurnBright(action, dev, 0) == True:
            newBrightness = 100
         if self.RFXTRX.TurnBright(action, dev, newBrightness) == True:
         if sendSuccess:
         #if self.RFXTRX.TurnDim(action, dev) == True:
            newBrightness = 0
         if self.RFXTRX.TurnDim(action, dev, newBrightness) == True:
         if sendSuccess:
and for RFXTRX.py I changed
   def TurnBright(self, action, dev,BrightLevel):
      return self.TurnDevice(action, dev, 'Bright', BrightLevel)
   def TurnDim(self, action, dev):
      return self.TurnDevice(action, dev, 'Dimm', 0)
to
   def TurnBright(self, action, dev, BrightLevel):
   def TurnDim(self, action, dev, BrightLevel):
      return self.TurnDevice(action, dev, 'Dimm', BrightLevel)
which seems to work.
BTW, it seems that the code in plugin.py will always set sendSuccess to true, regardless of result?
Mon Jan 21, 2013 2:33 pm
RJdeKok offline
I implement your suggestions in the next release... But with a small correction around the SendSucces.
sendSuccess is the status of the transmit command (always successful). As NEXA devices use one-way communication it is not possible to indicate the status of the NEXA module.
Users browsing this forum: No registered users and 18 guests
