Device name containing accented characters
Fri Nov 16, 2012 12:01 pm
DomoPat offline
I have a device whose name is "Entrée", with an accent in the fourth character, works fine except when I use it in an Action group. Then I have an error in the log:
Action Group Parfumateur 3 heures
RFXCOM Error Error in plugin execution ExecuteAction:
File "plugin.py", line 76, in actionControlDimmerRelay
<type 'exceptions.UnicodeEncodeError'>: 'ascii' codec can't encode character u'\xe9' in position 4: ordinal not in range(128)
ho ho, error in position 4 !
Line 76 is the last line of:
   ###### TURN ON ######
         self.debugLog(u"Variabelen: \"%s\" %s %s" % (self, action, dev))
As it is a 'debugging line' I commented it and the error disappeared, but it might need a better fix. I don't see why the accent crashes, my rudimentary knowldege of Python tells me the 'u' should take care of that, but evidently not.
Mon Nov 19, 2012 3:57 pm
Re: Device name containing accented characters
Try changing this line:
to:
         self.debugLog(u"Variabelen: \"%s\" %s %s" % (self, action, dev.name))
Indigo does handle logging unicode strings correctly, but the original line is trying to dump the entire dev instance to the log file. The code that converts the object instance attributes to key/value strings isn't handling the unicode conversion optimally, which is why the error occurs. I'll look into improving that. In the mean time, if you change it to explicitly just log the name and not the entire instance, it should prevent the error.
Mon Nov 19, 2012 4:33 pm
I believe I have Indigo's handling of logging the entire device instance working in the next beta of Indigo 6 (not yet available).
Tue Nov 20, 2012 4:38 am
DomoPat offline
Thank you for the help and the explanation of the solution, I learned a bit more. I see that in the other cases it is dev.name that is used, not the whole instance.
Tue Nov 20, 2012 1:52 pm
nsheldon offline
Yay! :-) That bit of unicode mishandling in the device key:value display method was wreaking havoc on my Pioneer Receiver plugin's debugLog calls when any of the device states contained a special character (Internet radio station names, etc), to the point where I just had to catch the error and basically say "I can't show you the device info because it's special." Hahaha.
Tue Nov 20, 2012 3:47 pm
RJdeKok offline
The problem is solved, a new version is available here:http://www.rjdekok.nl/downloads/RFXCOM.indigoPlugin.zip
