Cannot add detected device correctly (Possible bug?)
Tue Oct 30, 2012 8:19 am
I'm having an issue adding a homeeasy doorbell to my system, the RFXtrx433 recognises it and puts it in the error log as this:
30 Oct 2012 13:35:49
  RFXCOM Debug                    processing: 7 16 1 18 78 8 7 96 (07 10 01 12 4E 08 07 60)
  RFXCOM Debug                    Switch Command N8 7808 command 7 received
  RFXCOM Error                    unknown device detected (id = 7808, type = 16). Select a ARC/X10 Switch from the list of devices
  RFXCOM Debug                    ++++++++++++++
However when i go to create an ARC or X10 switch i only have the option to add the module address, not the type and as such when i press the button I just get the same error. I’ve tried all the different types of switch it allows, but to no avail!
Any ideas?
Mon Nov 05, 2012 2:53 pm
RJdeKok offline
Re: Cannot add detected device correctly (Possible bug?)
I have to apologize, the error text is not very clear. Will be solved in the next version of the plugin.
But this is how to configure it:
This will result in:
Mon Nov 05, 2012 4:10 pm
Perfecto, thanks!
