Sensor data not received by RFXrec
Posted:
Thu Oct 18, 2012 5:06 am
by hamw
I have 5 Oregon Scientific sensors, three temp/humidity in crawl spaces, one temp/humidity outside and a rain gauge, all put in within the last few months. Once positioned within range of the RFX receiver, they have all worked well. However, since Tuesday two of them have stopped being recorded by RFX. They are actually the two closest to the receiver so it is unlikely to be a signal issue. I tried reinstalling RFXrec and changing the device ID and saving, changing back, as well as unplugging the RFXrec device. No luck, and I doubt these two would have failed simultaneously. Any ideas?
Re: Sensor data not received by RFXrec
Posted:
Thu Oct 18, 2012 7:51 am
by RJdeKok
What do you see in the event log?
You have to switch on 'enable debug logging' in the configuration of the Plugin.
Posted:
Thu Oct 18, 2012 9:03 am
by hamw
Looks like the RFXrec is only picking up 3 of the 5 sensors. Hard to believe two new sensors would fail at the same time but I guess I need to check them when I get back....
- Code: Select all
RFXCOM Debug Temp sensor 486 now 61.88 degrees and 96 humidity.
RFXCOM Debug Temp sensor 486 in list
RFXCOM Debug UpdateMinMax state temperature value 61.9
RFXCOM Debug check if new day: last date 2012/10/18, new date 2012/10/18
RFXCOM Debug UpdateMinMax state humidity value 96
RFXCOM Debug ++++++++++++++
RFXCOM Debug processing: 11 85 2 2 21 0 0 0 0 12 190 89 (0B 55 02 02 15 00 00 00 00 0C BE 59)
RFXCOM Debug Rainsensor 21 values updated rate:0.000000 total:12.830000
RFXCOM Debug Rainsensor 21 in list
RFXCOM Debug saving plugin props
RFXCOM Debug <<-- entering deviceUpdated: RFX Rain Gauge
RFXCOM Debug deviceStop called. Removed device RFX Rain Gauge.
RFXCOM Debug deviceStart called. Adding device RFX Rain Gauge, type: Rainsensor
RFXCOM Debug Adding sensor 21.
18Oct, 2012 10:46:16 AM
RFXCOM Debug processing: 10 82 1 3 5 1 0 215 44 1 89 (0A 52 01 03 05 01 00 D7 2C 01 59)
RFXCOM Debug Temp sensor 261 now 70.70 degrees and 44 humidity.
RFXCOM Debug Temp sensor 261 in list
RFXCOM Debug UpdateMinMax state temperature value 70.7
RFXCOM Debug UpdateMinMax state humidity value 44
RFXCOM Debug processing: 10 82 1 4 230 1 0 166 96 3 89 (0A 52 01 04 E6 01 00 A6 60 03 59)
18Oct, 2012 10:46:41 AM
RFXCOM Debug processing: 11 85 2 5 21 0 0 0 0 12 190 89 (0B 55 02 05 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 6 5 1 0 215 44 1 89 (0A 52 01 06 05 01 00 D7 2C 01 59)
RFXCOM Debug processing: 10 82 1 7 230 1 0 166 96 3 89 (0A 52 01 07 E6 01 00 A6 60 03 59)
18Oct, 2012 10:47:28 AM
RFXCOM Debug processing: 11 85 2 8 21 0 0 0 0 12 190 89 (0B 55 02 08 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 9 5 1 0 214 44 1 89 (0A 52 01 09 05 01 00 D6 2C 01 59)
RFXCOM Debug Temp sensor 261 now 70.52 degrees and 44 humidity.
RFXCOM Debug UpdateMinMax state temperature value 70.5
RFXCOM Debug processing: 10 82 1 10 230 1 0 166 96 3 89 (0A 52 01 0A E6 01 00 A6 60 03 59)
18Oct, 2012 10:47:58 AM
Received INSTEON "Thermostat Fam Study" humidity changed to 47.0
18Oct, 2012 10:48:13 AM
RFXCOM Debug processing: 10 82 1 11 5 1 0 214 44 1 89 (0A 52 01 0B 05 01 00 D6 2C 01 59)
RFXCOM Debug processing: 10 82 1 12 230 1 0 166 96 3 89 (0A 52 01 0C E6 01 00 A6 60 03 59)
18Oct, 2012 10:48:52 AM
RFXCOM Debug processing: 10 82 1 13 5 1 0 214 44 1 89 (0A 52 01 0D 05 01 00 D6 2C 01 59)
RFXCOM Debug processing: 10 82 1 14 230 1 0 166 96 3 89 (0A 52 01 0E E6 01 00 A6 60 03 59)
Received INSTEON "Thermostat Main Bedrooms" humidity changed to 45.0
RFXCOM Debug processing: 11 85 2 15 21 0 0 0 0 12 190 89 (0B 55 02 0F 15 00 00 00 00 0C BE 59)
Received INSTEON "Thermostat Fam Study" humidity changed to 46.0
18Oct, 2012 10:49:31 AM
RFXCOM Debug processing: 10 82 1 16 5 1 0 214 44 1 89 (0A 52 01 10 05 01 00 D6 2C 01 59)
RFXCOM Debug processing: 10 82 1 17 230 1 0 166 96 3 89 (0A 52 01 11 E6 01 00 A6 60 03 59)
RFXCOM Debug processing: 11 85 2 18 21 0 0 0 0 12 190 89 (0B 55 02 12 15 00 00 00 00 0C BE 59)
18Oct, 2012 10:50:06 AM
Received INSTEON "Thermostat Main Bedrooms" humidity changed to 46.0
RFXCOM Debug processing: 10 82 1 19 5 1 0 214 44 1 89 (0A 52 01 13 05 01 00 D6 2C 01 59)
RFXCOM Debug processing: 10 82 1 20 230 1 0 166 96 3 89 (0A 52 01 14 E6 01 00 A6 60 03 59)
18Oct, 2012 10:50:36 AM
RFXCOM Debug processing: 11 85 2 21 21 0 0 0 0 12 190 89 (0B 55 02 15 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 22 5 1 0 213 44 1 89 (0A 52 01 16 05 01 00 D5 2C 01 59)
RFXCOM Debug Temp sensor 261 now 70.34 degrees and 44 humidity.
RFXCOM Debug UpdateMinMax state temperature value 70.3
Received INSTEON "Thermostat GameRm" temperature changed to 66.0
18Oct, 2012 10:51:12 AM
18Oct, 2012 10:51:28 AM
RFXCOM Debug processing: 10 82 1 23 5 1 0 213 44 1 89 (0A 52 01 17 05 01 00 D5 2C 01 59)
RFXCOM Debug processing: 10 82 1 24 230 1 0 166 96 3 89 (0A 52 01 18 E6 01 00 A6 60 03 59)
18Oct, 2012 10:52:02 AM
Received INSTEON "Thermostat GameRm" temperature changed to 65.0
RFXCOM Debug processing: 10 82 1 25 5 1 0 213 44 1 89 (0A 52 01 19 05 01 00 D5 2C 01 59)
RFXCOM Debug processing: 11 85 2 26 21 0 0 0 0 12 190 89 (0B 55 02 1A 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 27 230 1 0 166 96 3 89 (0A 52 01 1B E6 01 00 A6 60 03 59)
18Oct, 2012 10:52:46 AM
RFXCOM Debug processing: 10 82 1 28 5 1 0 213 44 1 89 (0A 52 01 1C 05 01 00 D5 2C 01 59)
RFXCOM Debug processing: 10 82 1 29 230 1 0 166 96 3 89 (0A 52 01 1D E6 01 00 A6 60 03 59)
RFXCOM Debug processing: 11 85 2 30 21 0 0 0 0 12 190 89 (0B 55 02 1E 15 00 00 00 00 0C BE 59)
18Oct, 2012 10:53:22 AM
RFXCOM Debug processing: 10 82 1 31 5 1 0 213 44 1 89 (0A 52 01 1F 05 01 00 D5 2C 01 59)
RFXCOM Debug processing: 10 82 1 32 230 1 0 166 96 3 89 (0A 52 01 20 E6 01 00 A6 60 03 59)
RFXCOM Debug processing: 11 85 2 33 21 0 0 0 0 12 190 89 (0B 55 02 21 15 00 00 00 00 0C BE 59)
18Oct, 2012 10:54:04 AM
RFXCOM Debug processing: 10 82 1 34 5 1 0 213 45 1 89 (0A 52 01 22 05 01 00 D5 2D 01 59)
RFXCOM Debug Temp sensor 261 now 70.34 degrees and 45 humidity.
RFXCOM Debug UpdateMinMax state humidity value 45
RFXCOM Debug processing: 10 82 1 35 230 1 0 166 96 3 89 (0A 52 01 23 E6 01 00 A6 60 03 59)
18Oct, 2012 10:54:31 AM
RFXCOM Debug processing: 11 85 2 36 21 0 0 0 0 12 190 89 (0B 55 02 24 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 37 5 1 0 213 45 1 89 (0A 52 01 25 05 01 00 D5 2D 01 59)
RFXCOM Debug processing: 10 82 1 38 230 1 0 166 96 3 89 (0A 52 01 26 E6 01 00 A6 60 03 59)
Schedule Crawl Space Fans (delayed action)
Sent X10 "Water 4 CrawlSp Fan Fam Rm" off
Sent X10 "Water 5 CrawlSp Fan Main House" off
Sent X10 "Water 6 CrawlSp Fan Game Room" off
18Oct, 2012 10:55:18 AM
RFXCOM Debug processing: 11 85 2 39 21 0 0 0 0 12 190 89 (0B 55 02 27 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 40 5 1 0 213 45 1 89 (0A 52 01 28 05 01 00 D5 2D 01 59)
RFXCOM Debug processing: 10 82 1 41 230 1 0 166 96 3 89 (0A 52 01 29 E6 01 00 A6 60 03 59)
18Oct, 2012 10:56:05 AM
RFXCOM Debug processing: 11 85 2 42 21 0 0 0 0 12 190 89 (0B 55 02 2A 15 00 00 00 00 0C BE 59)
RFXCOM Debug processing: 10 82 1 43 230 1 0 166 96 3 89 (0A 52 01 2B E6 01 00 A6 60 03 59)
18Oct, 2012 10:56:36 AM
RFXCOM Debug processing: 10 82 1 44 5 1 0 213 45 1 89 (0A 52 01 2C 05 01 00 D5 2D 01 59)
RFXCOM Debug processing: 10 82 1 45 230 1 0 166 96 3 89 (0A 52 01 2D E6 01 00 A6 60 03 59)
RFXCOM Debug processing: 11 85 2 46 21 0 0 0 0 12 190 89 (0B 55 02 2E 15 00 00 00 00 0C BE 59)
Posted:
Fri Oct 19, 2012 4:46 pm
by hamw
So I went down into the crawl space and fetched one of the temp/humidity sensors; brought it up and it connected immediately to the RFXCOM. The battery level is "10". Nothing wrong at all. So that makes me wonder why it all of a sudden would stop being received? Should I just get an antenna and forget about it? Or is there something up with the RFXCOM, which otherwise seems to be behaving normally?
Posted:
Sat Oct 20, 2012 8:22 am
by hamw
Of course now, having spent the effort to observe, troubleshoot, post etc, they are updating as normal without any changes to the system.... In fact, while I did bring up the "Family" sensor to definitely within range of the RFXCOM, I didn't touch the "Main" sensor, which came back on line totally by itself and now shows the strongest signal strength of any of the sensors.
Oh well, the miracles of technology.
Maybe I'll get an antenna anyway.
Posted:
Wed Oct 24, 2012 7:19 am
by RJdeKok
The sensors have a STR =5. This is on the edge... 4 is absolutely to low and a minimum of 6-7 is recommended.
To increase the receiving range you can connect for example a
http://www.conrad.com order nr 190073 433MHz ground plane antenna with BNC coax cable,
Or a
http://www.radioshack.com/product/index ... PerPage=60 scanner antenna. This antenna needs a coax cable with PL-259 and SMA or BNC connector.
This adapter can be used for SMA- to BNC
http://www.ebay.com/itm/BNC-female-SMA- ... 2a03ea8391 The location of the sensor and the RFXCOM is also important if the RF signal has to pass through walls. See chapter 2.4 in the RFXtrx User Guide
http://www.rfxcom.com/documents/RFXtrx% ... 0Guide.pdf It is expected that RF interference is happening if sensor signals disappear for several hours. RF interference will occur if sensors of the same type are configured to the same channel.
If sensors disappear for a longer period the source can be another transmitter that is transmitting continuously or with short intervals. If X10 MS13 sensors are in use check the battery in this sensor because when the battery becomes almost empty the MS13 starts transmitting a weak continuous RF signal but just enough to disturb the sensitive RFXCOM receiving.
Posted:
Thu Oct 25, 2012 10:08 pm
by hamw
It does look like a signal issue; surprising though that the two sensors that stopped working have STR of 6 and 7, and the others, which are lower, behaved just fine.
I don't have any X10 RF devices, but do have some AcuRite sensors which are still installed. AFAIK they are not received by the RFXrec, but could they cause interference months after the install?
Posted:
Sat Apr 20, 2013 7:37 am
by midd
I'm in the same boat with my Oregon Scientific Rain Gauge. Last season it worked as it should. I brought the Rain Gauge in for the winter. Now when I put it out the RFXrec and Rain Gauge show they are connected but no data is sent over. Battery level is at 10. My RFXrec is in the basement but like i said last year it worked fine. Had a decent rain shower last night and no data was recorded. Signal Strength bounces between 6-7. I brought the rain gauge inside and put it right next to the RFXrec and it only shows a strength of 7.
I should add that it does do periodic updates as the date and time are reflected. The only data that is delivered is the rainfall total. But it's always at 9.72 inches.
