RFXrec433 and OS temperature accuracy lost
Tue Aug 28, 2012 4:02 pm
LeonardSmale offline
Why are the temperatures only accurate to a degree when the OS is reporting temperatures to 1/10th of a degree C?
This considerable devalues the usefullness when I've got temperatures that change slowly (like hot tub water).
Sat Sep 01, 2012 6:56 pm
Korey offline
Re: RFXrec433 and OS temperature accuracy lost
+1
More accurate readings from the plugin please!
Korey
Wed Sep 05, 2012 4:28 am
RJdeKok offline
Your wish is my command...
A new version of the RFXCOM Plugin (V1.2.0) is available here: http://www.rjdekok.nl/downloads/RFXCOM.indigoPlugin.zip
Temperatures now have a accuracy of .1 degrees.
Wed Sep 05, 2012 8:01 am
Korey offline
:D :D Thank you !!! :D :D
Korey
Wed Sep 05, 2012 12:13 pm
Korey offline
Seems like perhaps the plugin is not calculating conversion to Ferinheight correctly.
This is the log output selecting ºF in the plugin settings:
RFXCOM Debug processing: 8 80 3 3 185 1 0 187 105 (08 50 03 03 B9 01 00 BB 69)
RFXCOM Debug Temp sensor 441 now 66.00 degrees and 0 humidity.
RFXCOM Debug Temp sensor 441 in list
RFXCOM Debug UpdateMinMax state temperature value 66.0
RFXCOM Debug check if new day: last date 2012/09/05, new date 2012/09/05
RFXCOM Debug UpdateMinMax state humidity value 0
RFXCOM Debug ++++++++++++++
This is the log output selecting ºC in the plugin settings:
RFXCOM Debug processing: 8 80 3 0 185 1 0 188 105 (08 50 03 00 B9 01 00 BC 69)
RFXCOM Debug Temp sensor 441 now 18.80 degrees and 0 humidity.
Trigger Pond Temp Update
RFXCOM Debug UpdateMinMax state temperature value 18.8
18.80 ºC = 65.84 ºF
Seems like the plugging is rounding up for the ºF settings. :shock:
Korey
Wed Sep 05, 2012 4:58 pm
johnpolasek offline
That does appear to be the case; I have 4 temp sensors reading in Fahrenheit, and all four of them are showing xx.0 in rev 1.2.2... Looks like you round to the closest degree, then format the integer value to the nearest tenth.
Thu Sep 06, 2012 11:41 am
RJdeKok offline
Again a new version of the RFXCOM Plugin (V1.2.3) is available here: http://www.rjdekok.nl/downloads/RFXCOM.indigoPlugin.zip
- Temperatures fahrenheit now have a accuracy of .1 degrees.
- Barometer (Type84) implemented
Thu Sep 06, 2012 2:27 pm
Korey offline
Works great!
:) :D Thank You!! :D :)
Korey
