Just upgraded to 7.2 and getting RFXCOM errors
Posted: Sat Nov 10, 2018 12:33 pm
Hi
the upgrade worked fine, just odd that I now have two Indigo apps in my Applications Indigo and Indigo 7.2.
It all went well until I moved my Mac Mini downstairs - The intent is to move Indigo to a recently updated iMac. But not started that yet,
Plugged in the RFXCOM
The Logs show
Not sure how or why a reboot would cause this.
Any ideas on how to get it fixed?
The Logs show
- Code: Select all
Enabling plugin "RFXCOM 2.1.8"
Starting plugin "RFXCOM 2.1.8" (pid 7850)
Started plugin "RFXCOM 2.1.8"
RFXCOM Error "RFXCOM serial port" serial port open error: [Errno 2] could not open port /dev/cu.usbserial-A13X8U3: [Errno 2] No such file or directory: '/dev/cu.usbserial-A13X8U3'
RFXCOM Error make sure the USB virtual serial port driver (ex: FTDI driver) is installed and correct port is selected
RFXCOM Error serial port could not be opened
