RFXCOM Temp Status Without Decimal
Posted:
Wed May 16, 2018 12:29 pm
by ckeyes888
Hey,
Just a feature request for the RFXCOM plugin.
It would be very helpful to me if the temperature were reported without the decimal place.
70.2 would simply be 70 etc.
I use images on my CP’s so I wouldn’t have to convert that state to an integer every time it changed...which very
often doesn’t work.
Carl
Re: RFXCOM Temp Status Without Decimal
Posted:
Thu May 17, 2018 1:13 pm
by kw123
I believe I have that finished.
will add to the GitHub site.
will have 3 settings in config
digits for temp, rainfall, wind
besides units for ...
then ALL values for temp (min/max ..) will be x digits like here for 0 digits:
- Screen Shot 2018-05-17 at 14.12.14.png (15.34 KiB) Viewed 719 times
Posted:
Thu May 17, 2018 2:16 pm
by ckeyes888
That would be awesome. Looking forward to it.
Carl
Posted:
Thu May 17, 2018 9:48 pm
by kw123
https://www.dropbox.com/s/xjzqt1hjybhzomg/RFXCOM-v-2.1.11.zip?dl=1Carl ,
could you try this one. I have tested with
temp; temp/humidity, pool temp, wind, rain sensor.
with many display variations. mine seem to work .
You can set # of digits to 0/1/2 for temp, wind speed, rain rates and amounts in config
When it works for you I will put on GitHub for upload
Posted:
Fri May 18, 2018 9:30 am
by ckeyes888
Unless I’m missing something I don’t see any change other than the menu showing the amount of digits.
Regardless of how many digits I set for the temp it always shows the decimal. e.g. 70.2
Edit: Check that. After resetting and setting it to 0 the decimal is gone. Love it!
Thanks a bunch!
Carl
Posted:
Fri May 18, 2018 9:32 am
by kw123
which sensor type do you use and does the value change?
I tried temperature sensor and RFXcom sensor they both work for me..
Posted:
Fri May 18, 2018 11:39 am
by ckeyes888
Yes, as I said in my edit it does work great now. When I first tried it it didn’t remove the decimal
but after a reload of the plugin it did.
Carl
Posted:
Fri May 18, 2018 11:51 am
by kw123
Thanks for testing.
After the change it needs to get new data. It will not update old data
Posted:
Fri May 18, 2018 12:07 pm
by kw123
published on the GitHub site, will ask Matt/Jay to push it to the regular site.
