change format to not have 2.5000000000001 strings in states
Tue Oct 03, 2017 11:07 pm
suggestion to the authors or Matt,Jay:
with adding decimalPlaces :
   def _addToBatchStatesChange(self, dev, key="", value="",decimalPlaces=""):
      devId = dev.id
      if devId not in self.batchStatesUpdate:
         self.batchStatesUpdate[devId] = []
      if decimalPlaces == "":
         self.batchStatesUpdate[devId].append({"key":key, "value":value})
         self.batchStatesUpdate[devId].append({"key":key, "value":value,"decimalPlaces":decimalPlaces})
      return
and adding decimalplaces to each of the calls with numbers to e.g.:
         self._addToBatchStatesChange(self.tempList[sensor], key=u"currentMonthTotal", value=currentMonthTotal,decimalPlaces=2)
It looks much better ===> "2.5000000000001" becomes "2.50"
Tue Oct 03, 2017 11:11 pm
Re: change format to not have 2.5000000000001 strings in sta
Wed Oct 04, 2017 10:07 am
know the GitHub site.
The posted version does not have this option.
And I found no way to post/comment anything.
Thats why I posted it here.
Wed Oct 04, 2017 1:04 pm
Fork it, change it, and issue a pull request - since it's open source you can do the work yourself, that's the best way to get it done. Alternately, you can add an issue on Github for it and perhaps someone else will do it.
