ACM3500 RFX setup?
Mon May 29, 2017 3:41 pm
marcel langelaan offline
ACM3500 RFX setup?
I try to configure a ACM3500, but don't see how. An ACM3500 is a KAKU switch with 3 integrated switches.
The following information i receive from de RFXCOM Debug. Control of this ACM3500 performed with a setup outside Indigo.
I don't see how to seperate the 3 switches because they use the same housecode and unicode.
Please advice.
Received info:
ACM3500 prt 3
processing: 11 17 0 1 3 128 0 0 4 1 15 112 (0B 11 00 01 03 80 00 00 04 01 0F 70)
RFXCOM Debug AC Switch with housecode 30800000 and unitcode 04 command 1 received
RFXCOM Debug Switch Command 30800000-04 in list, command=On
RFXCOM Debug ++++++++++++++
RFXCOM Debug processing: 11 17 0 2 3 128 0 0 4 0 0 112 (0B 11 00 02 03 80 00 00 04 00 00 70)
RFXCOM Debug AC Switch with housecode 30800000 and unitcode 04 command 0 received
RFXCOM Debug Switch Command 30800000-04 in list, command=Off
ACM3500 prt 2
processing: 11 17 0 14 3 128 0 0 4 1 15 112 (0B 11 00 0E 03 80 00 00 04 01 0F 70)
RFXCOM Debug processing: 11 17 0 15 3 128 0 0 4 0 0 112 (0B 11 00 0F 03 80 00 00 04 00 00 70)
ACM3500 prt 1
processing: 11 17 0 21 3 128 0 0 4 1 15 112 (0B 11 00 15 03 80 00 00 04 01 0F 70)
RFXCOM Debug processing: 11 17 0 22 3 128 0 0 4 0 0 112 (0B 11 00 16 03 80 00 00 04 00 00 70)
