Indigo Responding differently than expected to LightWaveRF
Sun Apr 03, 2016 7:24 am
Busta999 offline
Hi
On Day 5 of Indigo so be gentle with me please....
I'm pressing Button two on my Lightwaverf remote - that I do not have setup in Indigo and it responding as if I pressed Button 3.
Indigo does NOT do this when Button 1 is pressed or Button 4, it does work on Button 3 as described and setup below.
It is driving me crazy trying to understand why this is going wrong.
I have setup a Switch (I thought would be a Remote but can't see how to make that work in Indigo) The JSJSLW100WH
It has 5 On buttons, 5 Off Buttons, A Mood 1 On, and an Everything Off
The Switch is setup as a Device, RFXCOM/LightWave Switch, Name of SwitchMaster Bedroom Mike #3, Device Settings f0ef41 Unicode 3
My understanding of this is that ONLY Button three on the remote will be detected.
Then I created a trigger
Master Bedroom Dim Mike
Device State Changed/ Switch Master Bedroom Mike #3/Command/Becomes Equal to/ On
So If the On Button Three on Mike's Lightwave Remote Control in the Master Bedroom is pressed the following will occur
Condition:-
Always set with No conditions.
Actions:-
Execute Action Group (server Actions)
Master Bed Dim
If press Button 3 On - every thing works OK.
If I press Button 2 On the following occurs - even though I have not set this button up at all - see Screen Grab
RFXCOM Debug processing: 10 20 0 192 240 239 65 2 1 0 96 (0A 14 00 C0 F0 EF 41 02 01 00 60)
RFXCOM Debug LW Switch with housecode f0ef41 and unitcode 02 command 1 received (level:0)
RFXCOM Error probably a LW Remote?
RFXCOM Debug LW Remote with housecode f0ef41 command 1 received (level:0)
RFXCOM Debug Switch Command f0ef41 in list, unit=02, command=On
Error device "Switch Master Bedroom Mike #3" state key unit not defined (ignoring update request)
Trigger Master Bedroom Dim Mike
Action Group Master Bed Dim
RFXCOM Debug ++++++++++++++
RFXCOM Debug Actions...TurnOn
RFXCOM Debug Turn LWAppliance Appliance/Dimmer On (level 0).
RFXCOM Debug Address 335063
RFXCOM Debug housecode:1
RFXCOM Debug device type:LWAppliance
RFXCOM Debug device subtype:0 / Command:On
RFXCOM Debug device level:0.0
RFXCOM Debug send x10 cmd: 10 20 0 0 51 80 99 1 1 0 112 (0A 14 00 00 33 50 63 01 01 00 70)
Sent Hue Lights "Master Floor" on to 30 at ramp rate 2.0 sec.
Sent Hue Lights "Master Mike" off at ramp rate 0.0 sec.
Sent Hue Lights "Master Dawn" off at ramp rate 0.0 sec.
Sent Hue Lights "Landing Globe" on to 30 at ramp rate 2.0 sec.
RFXCOM Debug processing: 4 2 1 0 0 (04 02 01 00 00)
RFXCOM Debug ACK Message ACK, transmit OK
RFXCOM Debug sent "Master Mike Nightlight" on
RFXCOM Debug sent "Master Dawn Nightlight" on
Indigo.tiff
Indigo.tiff (428.26 KiB) Viewed 825 times
Mon Apr 04, 2016 12:47 am
Re: Indigo Responding differently than expected to LightWave
Can you attach a screenshot of the device config page please?
Also just FYI it's best to create triggers using the last updated date, because if you press the same button twice without pressing another one it'll ignore it as its already on :)
Mon Apr 04, 2016 2:55 am
Busta999 offline
Durosity, thanks.
I blew the remote away, took out the battery and have left it on the naughty step for awhile :-)
I added a totally new remote and set that up. It appears to be working properly. I'll test it more thoroughly today.
Is there a better way to set up these remotes other than set up a device for every button pair? On these remotes that could mean setting up 17 devices just for one remote? That is a lot of work. I have over a dozen of these remotes, that could mean over 200 devices just for the remote controls.
Then you have to set up 2 triggers for each button pairs, that would be 400 triggers.
Is there a more efficient way, and I am being dumb here?
Mon Apr 04, 2016 4:16 am
Busta999 offline
Durosity
If I understand you correctly.
"best to create triggers using the last updated date, because if you press the same button twice without pressing another one it'll ignore it as its already on :)"
That will Trap any press of the button pair and then catch the one you are after by putting in a Conditional Command to trap which the two buttons was actually pressed.
I'll give that a try, thanks
Wed Apr 06, 2016 5:22 pm
Yeah, generally what I do is have it set to trigger on the date change, then a python script to check what changed on the device and what action to perform based on that. If you search the forum there's some posts about it from a few years ago.
