Measuring Signal Strength?
Sat Nov 14, 2015 11:11 am
Is it possible to measure signal strength of the RFXtrx433E?
I have just replaced the aerial and would like to understand if it has made the signal more reliable / stronger. :)
Sat Nov 14, 2015 11:37 am
Re: Measuring Signal Strength?
Click on an rfx device and move the lower pan up. There you see the signal strength.
Sat Nov 14, 2015 12:26 pm
Not seeing it on this device (battery Mood Switch):
or this one (mains socket plug switch):
Am I looking in the correct place?
Sat Nov 14, 2015 2:54 pm
this what I see. If you don't see anything with your device you should ask the plugin author.
Screen Shot 2015-11-14 at 2.52.58 PM.png (43.58 KiB) Viewed 900 times
Mon Nov 16, 2015 4:01 am
Maybe it depends on the device type?
