Some Errors
Fri Sep 11, 2015 3:18 am
lindehoff offline
Some Errors
Hi
Every so often I get some errors:
RFXCOM Error                    Error in plugin execution runConcurrentThread:
  File "plugin.py", line 290, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 1851, in startComm
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 582, in processPacket
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 954, in showRain
<type 'exceptions.KeyError'>: key raintotal not found in dict
  RFXCOM Error                    plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
  Error                           device "Wind 2 Dir at Speed" state key humidity not defined (ignoring update request)
  Error                           device "Wind 2 Dir at Speed" state key humidityStatus not defined (ignoring update request)
Thu Dec 10, 2015 4:47 pm
RJdeKok offline
Re: Some Errors
Just before the error message there should be something like this in the log:
processing: 16 86 4 87 132 22 1 14 0 23 0 22 0 54 0 34 121 (10 56 04 57 84 16 01 0E 00 17 00 16 00 36 00 22 79)
Can you send me that part of the log and the messages after this line.
Thanks.
