Rain Gauge OR-RGR126
Sun May 18, 2014 6:43 am
midd offline
Does anyone know if this one is compatible with the RFXCOM plugin?
http://www.ebay.com/itm/Oregon-Scientif ... 1461024537
Indigo 7, Monterey (12.1) on a 2009 Mac Pro..
Sun May 18, 2014 10:40 am
Korey offline
Re: Rain Gauge OR-RGR126
It should be, I believe it's the same unit as the original I have (PCR800) just with a longer range antenna.
Korey
Sun May 18, 2014 10:44 am
the 2 sensors are, I have exactly those. The display is not as it does not transmit any information.
Sun May 18, 2014 1:18 pm
midd offline
Thanks. I've gone through my 2nd PCR 800 in 2 years.
Wed May 21, 2014 2:59 pm
midd offline
So I decided to bite the bullet and buy the OS RGR-126 from Amazon.com
http://www.amazon.com/Oregon-Scientific ... rain+gauge
From the pic, I was happy to see that the bucket itself had an external antenna which is why I purchased it. However, when it arrived, it had the same crappy internal spring antenna as the PCR 800. I was quite disappointed.
Mon Nov 02, 2015 3:08 pm
I had two and each died after ~ 1 year
... but figured it out what it is: the battery contacts are corroded (pretty bad for an outside rain sensor)
... but no solution yet. After wiggling the battery it works again .. for 1 day... need to may be solder the batteries to the contacts ? or may be we need special batteries with humidity tolerant contacts?
any suggestion?
