Plugin Error with RFXtrx315
Sat Nov 09, 2013 1:13 pm
tpthaler offline
Hello,
I just received my RFXtrx315 that I will be using for decoding/integrating with my Visonic security system. I temporarily disabled my RFXtrx433 just to make sure there were not any issues due to running both at the same time.
Anyways, when I use RFXCom's manager windows (test) program, I am able to decode and see my sensors just fine. But when I try seeing them in Indigo I get the following error (triggered after a sensor transmits):
File "plugin.py", line 224, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 1687, in startComm
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 426, in processPacket
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/RFXCOM.indigoPlugin/Contents/Server Plugin/RFXTRX.py", line 559, in handleSecurity
<type 'exceptions.UnicodeDecodeError'>: 'ascii' codec can't decode byte 0xe2 in position 37: ordinal not in range(128)
RFXCOM Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
RFXCOM Debug runConcurrentThread called
RFXCOM Debug startComm called
I am using the latest version of Indigo (6.0.4) and the latest version of the plugin (1.3.6).
Sat Nov 09, 2013 1:56 pm
tpthaler offline
Re: Plugin Error with RFXtrx315
I'm starting to try to debug this problem, and so far I can see that this line of code is causing the issue:
self.plugin.debugLog(u"Security sensor %d of type %s (%s) has status %s (%s)" % (sensor, subtype, device, status, stattext))
And more specifically, the variable (device) is causing the error...
Sat Nov 09, 2013 2:05 pm
Try this:
self.plugin.debugLog(u"Security sensor %d of type %s (%s) has status %s (%s)" % (sensor, subtype, unicode(device), status, stattext))
Sat Nov 09, 2013 2:10 pm
tpthaler offline
Found the bug:
device="Visonic PowerCode door/window sensor – primary contact (with alive packets)"
You can't have the '-' in the string text... This also shows up in other places in the code that my devices haven't entered yet...
Sat Nov 09, 2013 2:11 pm
tpthaler offline
matt (support) wrote:
Try this:
That didn't work, but if I changed the device set to a '-' using my keyboard and re-saving it also worked...
Sorry, I have never programmed in python before, so when I think I "fix" things, I really don't know what I am doing other than using my 20+ years of java / other coding experience as a crutch.
Sat Nov 09, 2013 2:13 pm
Note a traditional minus character shouldn't cause the error, so it is probably a special hyphen or dash character.
Sat Nov 09, 2013 2:16 pm
tpthaler offline
see above (must have been a euro '-' key or something)...
