RFXTrx433 with LightwaveRF - Initial Installation
Wed Jan 21, 2015 5:16 am
Re: RFXTrx433 with LightwaveRF - Initial Installation
I had a choice of two threads to post this reply and selected this one as it was the first (the second being Lightwave signal range in UK) :)
I have found a non-scripting way round the double button press issue on the LightwaveRF Mood Switch i.e. second and subsequent same button presses not being detected.
As recommended by durosity earlier in this thread, set-up a trigger to detect a device Last Updated change:
LightwaveRF Mood Switch > Last Updated > Has Any Change.
Then add a Condition: 'If device' > '< YOUR LIGHTWAVERF MOOD SWITCH NAME>' > 'Command' > 'is equal to' > '<YOUR MOOD SELECTION> e.g. Mood 3'
Then specify the action for selected Mood.
Now multiple button presses on the same button will work and no scripting involved :)
Fri Feb 13, 2015 1:08 pm
davidh offline
Very new to Indigo, but have the RFX433 working. I've added a Lightwave "Light Switch" device and following an earlier post was going to put it into pairing, send it a signal and hope it worked. But the added device doesn't seem to have any way at all to send a signal (I know Lightwave doesn't send signals back) as the Status section is blank. Comms are enabled, House code is 1 and device id 1. How do I get it to send anything? (If I add an X10 switch a little lightbulb appears in Status and it offers Turn On and Turn off).
Fri Feb 13, 2015 1:23 pm
From memory I think the device ID needs to be in the format of FFFFFF, perhaps try something like 123456?
Mon Jul 13, 2015 7:52 am
TOPS offline
Hi Guys,
Im using LWRF and RFX together and I was wondering how I set up an "All lights on" and an "All lights off" command from a control page, I want to be able to turn all my outside lighting on in one go, like a sort of "Panic" switch, I have my lighting grouped in folders, lounge, bedroom, kitchen, outside lights etc
Any help would be appreciated,
Dave
Mon Jul 13, 2015 10:09 am
b_weijenberg offline
you can add one ID-unit code in all modules you want to switch on/off with only one command.
Tue Jul 14, 2015 5:32 am
TOPS offline
Thanks for the reply, sorry to be a bit lame but where do I find the "ID-unit code"?
Cheers,
Dave
Tue Jul 28, 2015 3:04 pm
RJdeKok offline
Hi Dave,
Maybe I misunderstand you, but it looks like you can arrange this with an action group which turns all lights on or off.
In the control on your control page you can select a server action which triggers your action group which turns on your lights.
Or do I miss the point?
Bye, Robert.
Wed Jul 29, 2015 10:58 am
TOPS offline
Hi Robert,
Thanks for your reply, I'm using my LightwaveRF devices via the RFX Plugin and I don't seem to be able to set up an Action group with the RFX Plugin, any ideas? any one....
Regards,
Dave
Mon Aug 03, 2015 1:28 pm
RJdeKok offline
Hi Dave,
I hope this short example helps you:http://www.rjdekok.nl/actiongroup.pdf
Bye, Robert.
Tue Nov 17, 2015 11:19 am
TOPS offline
Hi Robert,
Very sorry for the very late reply :oops: your solution really helped, I'm all sorted now,
Dave
Sun Nov 13, 2016 7:57 am
Busta999 offline
Hi seeing some Odd behaviour
Added new LWRF Remote Control JSJSLW015 so I can control LWRF and Hue Lights in Kitchen
I can see the On button being pressed in the Event Log - BUT Indigo does not 'see' it.
RFXCOM Debug processing: 10 20 0 0 243 84 127 1 1 0 112 (0A 14 00 00 F3 54 7F 01 01 00 70)
RFXCOM Debug LW Switch with housecode f3547f and unitcode 01 command 1 received (level:0)
RFXCOM Debug Switch Command f3547f-01 in list, command=On
Created a new Device - LightwaveRF Switch Test 1 - see attachment 1
Indigo does not detect the Switch being used - see attachment 2
I have many Socket Rockets, LWRF Mood Switches all working great - just this one - Indigo just can't 'see' it.
Any ideas?
Indigo - LWRF 2.tiff
Indigo - LWRF 2.tiff (27.05 KiB) Viewed 2329 times
Indigo - LWRF 1.tiff
Indigo - LWRF 1.tiff (80.68 KiB) Viewed 2329 times
Sun Nov 13, 2016 10:40 pm
Are you using Indigo 7? If so, be sure and download to the version 2.0.3 of the plugin which is linked to on the first post here.
Thu Nov 17, 2016 3:25 pm
RJdeKok offline
Is this problem still actual or is it solved in version 2.03 by Matt?
Fri Jan 27, 2017 4:52 am
Busta999 offline
Sorry got distracted by a contract that kept me away from home for quite a while.
Got some time now so upgraded to 7, and fixing/setting up more in Indigo.
I try and run this issue again.
I'm running 2.1 of the plugin
