RFX reporting different units
Sat Apr 07, 2018 7:38 am
jenkins007 offline
I always use degrees in Fahrenheit. Since I updated to the latest version 2.1.9, I am now seeing 2 RFX Temperature sensors reported in F and 2 in Celsius. I changed the plugin to report in C, and the result is displayed below where 3 sensors report in C. The one in F is an additional wire connected to the master bedroom sensor (hence no voltage reading on it). When I configure RFX back to F, the Master bedroom reports back in F like in the first screen shot. I've been using these for many years with no errors.
Screen Shot 2018-04-07 at 8.11.42 AM.png (80.16 KiB) Viewed 5161 times
Screen Shot 2018-04-07 at 8.24.18 AM.png (84.43 KiB) Viewed 5161 times
Matthew
Sat Apr 07, 2018 10:03 am
Re: RFX reporting different units
https://www.dropbox.com/s/3kev5jvqh18qeav/RFXCOM-v-2.1.9.zip?dl=1
same version number, should fix it..
I have to apologize. I am traveling and have only a small laptop with slow connection .
so not pluginstore posting ,, (sorry jay)
Mon Apr 09, 2018 10:52 am
I've added this fix into a new release (2.1.10).
Tue Apr 10, 2018 9:32 pm
Karl & Matthew,
Have either of you seen the issue reported here or know what might be causing it?
I mistakenly thought that one might be related to the issue on this thread, but apparently it is not.
Tue Apr 10, 2018 11:58 pm
Will check tomorrow
Wed Apr 11, 2018 4:51 pm
This one is for Matt...
RFXcom plugin 2.1.10 Temperature Sensor device types
Diagnosis:
for existing devices the status column gets updated properly, when creating a NEW RFXcom temperature sensor device the status column does not get updated.
Devices.xml has
      <UiDisplayStateId>display</UiDisplayStateId>
properly defined. the corresponding State is defined as
      <States>
         <State id="display">
            <ValueType>String</ValueType>
            <TriggerLabel>Display</TriggerLabel>
            <ControlPageLabel>Display</ControlPageLabel>
         </State>
The state" display" also gets properly updated, but not the status column.
   RFXCOM Debug                    finalizeStatesChanges:TempInsideUpstairs :[{'decimalPlaces': 1, 'value': 74.66, 'key': u'temperature'}, {'value': 0, 'key': u'humidity'}, {'value': '', 'key': u'humidityStatus'}, {'value': 2, 'key': u'type'}, {'value': 100, 'key': u'batteryLevel'}, {'value': 6, 'key': u'signalStrength'}, {'decimalPlaces': 1, 'uiValue': u'74.7 \xb0F', 'value': 74.66, 'key': u'temperature'}, {'uiValue': u'74.7 \xb0F', 'value': u'74.7 \xb0F', 'key': u'display'}, {'value': '2018/04/11 17:14:29', 'key': u'lastUpdated'}]
I checked prefs file etc ... , but I simply can not find anything that is wrong. Especially when it works for defined devices, but not for NEWLY defined devcies - or for that matter if you change the device type to eg humidity sensor and back--
I am at the end of my toolset
Wed Apr 11, 2018 10:34 pm
Thanks for looking into this Karl. I think I tracked down what is going on. The issue is this Devices.xml change which updated the device type for the Temperature device from custom to sensor. That change was made (not by me) since using the native Indigo sensor device type better describes the device type. That allows, for example, other plugins to include those devices when enumerating all sensor devices.
The problem is that Indigo's native device types (everything but custom) ignore the UiDisplayStateId setting. This is so that the UI remains consistent for those device types. In the case of a sensor device, it always shows the state sensorValue, which is automatically included for sensor devices (don't add it to the XML). That value is also mirrored at the device instance level as dev.sensorValue (just like dev.brightness for dimmers). The problem is a bit more complex because changing the Devices.xml for the device type does not automatically update existing device instances. In fact there is no way to morph an existing device from one type to another without deleting and re-creating it. This explains why older devices work differently (they are still custom type and not sensor type) but newer ones don't show anything in the status column. The reason the status column is blank is because the state sensorValue is never being updated and that is the state that is always shown in the status column for a sensor device.
I think the best solution here (but I haven't looked a the RFX .py code to know for sure) might be to mirror the what is getting stuffed into the "display" state into the "sensorValue" state. This should probably be done conditionally though, only if "sensorValue" state exists (if "sensorValue" in dev.states:) because for older device instance that are still of type custom, it won't.
Thu Apr 12, 2018 7:13 am
that seems to work... (added in _finalizeStatesChanges),.. one issue the sensor value must be a number )..Temperature Sensors seems to be the only sensor dev type.
ps now I have to figure out how to add this to the GitHub site.. :oops:
Screen Shot 2018-04-12 at 08.08.19.png (57.69 KiB) Viewed 4932 times
Thu Apr 12, 2018 8:24 am
i posted a fixed version to the gihub site (version 2.1.11)
Thu Apr 12, 2018 12:11 pm
Hi Karl,
Looks like your Github Pull Request is into the wrong branch. Instead of being a request on the master/main branch it is in an old (and now stale) branch mbendiksen-blindst2t3. I don't think there is an easy way to move it over, so can you save off your changed files, pull down the latest version from the master branch, copy in your changes, and re-submit the pull request to the master branch?
Thanks again for looking into fixing this one!
Thu Apr 12, 2018 2:08 pm
trying ...
it looks as if create a new pull request is disabled
click on "New pull request" goes to :
Screen Shot 2018-04-12 at 15.05.54.png (58.1 KiB) Viewed 4883 times
can't add anything here.. I guess I am missing a basic step .. or I need to spend some time really going into GitHub ..
I am logged in with kw123
Thu Apr 12, 2018 2:27 pm
Thu Apr 12, 2018 4:35 pm
yes I did.. and I am stuck
0. downloadeddesktop , logged in, (kw123)
1. there is no fork button, used the menu, seems to work
2. after forking and replacing the 2 files I changed, I see the diff screens , all correct.
3. here I am stuck:::: "commit to Master" does not do anything .
any pointer what I did wrong would be appreciated.
Screen Shot 2018-04-12 at 17.33.34.png (224.98 KiB) Viewed 4849 times
Thu Apr 12, 2018 4:53 pm
... had to put something into the field "Summary" .. then I could "push up" ..
should I see the files on the GITHUB site?
thanks
Thu Apr 12, 2018 5:31 pm
When you look at your forked repo on Github, you can see a problem: you apparently deleted the README.md file and checked in the deletion - shouldn't have done that since we want to keep the README. The fix for that is to go back to your Github Desktop, switch to the History tab on the left side under the repo name, find the checkin where you deleted the readme, right-click it and select Revert This Commit. Switch back to the Changes tab and at the bottom you'll see "Revert blah blah" and an Undo button - click that and now you'll see the README appear back in the change file list. Commit that and it should put the README back to your forked repo.
Once that's done, switch back to look at your forked repo on Github. Above the file list you'll see a button titled New pull request - click that. You can then proceed with Step 3 of the wiki article.
