Got a new Awning. Some questions before the plunge.
Tue Aug 15, 2023 6:27 pm
hwitten offline
The Awning has a Somfy remote. I also have the Somfy MyLink app but of course getting control into Indigo would be much preferred.
Found this plugin and want to confirm that I understand correctly.
Is RFX433XL USB the correct device/bridge to order from RFXCOM?
Using the RFXCOM plugin I can then open/close/stop the Awning with Indigo?
Any other plugin/device I could optionally use or is the RFXCOM easiest/best?
Wed Aug 16, 2023 7:00 am
Re: Got a new Awning. Some questions before the plunge.
Personally, I think the Bond is way better. https://bondhome.io
Wed Aug 16, 2023 9:31 am
hwitten offline
I would only need the plain vanilla Bond Bridge and the Bond Home Plugin?
Wed Aug 16, 2023 10:21 am
Probably. I switched to the Bond Pro because it has better range and is powered over POE, so I don't need a wall wart. But the non-Pro also does IR.
I use it for my hurricane shutters, Christmas Tree lights, and multiple ceiling fans.
Wed Aug 16, 2023 10:39 am
hwitten offline
Thanks. Non-Pro on order. The awning is the only device, for now :wink:
Guess I'll move the Somfy Bridge to my White Elephant box.
