Numeric state value not appearing on legend
Tue Feb 09, 2021 7:20 am
MartinG offline
I have several panels in Grafana in which numeric values (eg Temperature) are plotted correctly on the chart, but where the values do not appear on the legend. Here's an example.
Grafana Chart.jpg (19.95 KiB) Viewed 1604 times
Using the device explorer in the Grafana plug reveals the following for the raw device data:
Grafana Home Dashboard             state.Temperature: 9.1 (INCLUDED)
Grafana Home Dashboard             state.Temperature.ui: 9.1C (INCLUDED)
Any idea where to start looking in order to fix this?
Thu Mar 11, 2021 9:31 am
vtmikel offline
Re: Numeric state value not appearing on legend
I've never seen that happen. If your device has a <state>.num version, try using that. Otherwise, maybe try using the mean() function in Grafana to force the data into a number. Maybe it's being interpreted as a string?
Mon Mar 15, 2021 4:11 am
MartinG offline
I think that's the problem - the chart seems to understand that it's a number, and renders accurately, but the legend does not. Using mean() doesn't work unfortunately,
