Problem with 24h time chunks (InfluxDB tweak needed?)
Tue May 05, 2020 7:59 pm
sumocomputers offline
I am trying to show last 30 days energy usage , with a bar for each 24 hour chunk (see screenshot).
The data in the Indigo variable gets incremented every 2 seconds from Midnight to Midnight, and then is reset.
The problem is that Grafana is displaying some of the data from say May 4th on both May 4th & May 5th (at least visually)
I have tried changing both the dashboard & overall preferences for time zone (Default, Local Browser Time, UTC), but that doesn't seem to fix it, nor does tinkering with the Time shift.
So then I saw that the time zone might need to be changed in InfluxDB, but wanted to check if I am missing something else obvious. Here is the link where I found this clue:
https://github.com/cockroachdb/cockroach/issues/20428
Screen Shot 2020-05-05 at 6.56.58 PM (1).jpeg (249.94 KiB) Viewed 1330 times
Wed May 06, 2020 10:57 am
Re: Problem with 24h time chunks (InfluxDB tweak needed?)
I think I fixed it. Had to change SELECT from last() to max()
Screen Shot 2020-05-06 at 9.54.58 AM.jpeg (284.4 KiB) Viewed 1302 times
