Plugin stops logging every midnight since upgrade
Sun Aug 25, 2019 10:00 am
Re: Plugin stops logging every midnight since upgrade
Nathan, have you looked into the source of the problem?
You did suggest yourself “some kind of exponential backoff” which is what’s been implemented here, but it doesn’t help if your DB is going offline, or your network is dropping, or...
Identifying that (eg trying manually at midnight) might cast light on the issue.
Sun Aug 25, 2019 8:08 pm
nathanw offline
I agree. The (IP) ping test didn't find any problems the other night; I'm going to try an influxdb.client.ping() loop tonight, with the same connection open, and see if I notice anything.
