Forgot Password Grafana
Mon Feb 11, 2019 1:21 am
Frakke offline
Hello,
I forgot the username and password for grafana.
Any idea how to reset this?
Already tried "forgot password", but didn't received any email.
Regards
Jelle
Wed Feb 13, 2019 6:36 am
vtmikel offline
Re: Forgot Password Grafana
Sorry for the delay.
Two options:
1. Use the CLI as the article says (http://docs.grafana.org/administration/cli/)
The CLI binary is available inside of the plugin bundle. So it would be somewhere like this location:
/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Grafana Home Dashboard.indigoPlugin/Contents/Server Plugin/servers/grafana/grafana-cli
I've never done this myself, let me know how it goes.
2. You can simply delete your Grafana database (it's located in the data directory you configured for the plugin), and restart the plugin. The password will be the default password again, but your data sources and dashboards will be erased. Before you do that, if you have a dashboard you want to keep, you can enable anonymous access via the plugin config, view your dashboard, and export it to JSON.
Wed Feb 13, 2019 7:33 am
Frakke offline
Reset with CLI was no success, tried it but didn't accept my new password..
Ended with deleting the DB.
Regards
Two options:
