Grafana install problem.
Sat Jan 19, 2019 12:09 pm
pxzel offline
Trying to install latest version of Grafana Home Dashboard 1.0.8 on my iMac running OS X 10.75 and Indigo 7.2
I'm getting these errors in the event log:
Grafana Home Dashboard Error Error in plugin execution InitializeMain:
File "plugin.py", line 16, in <module>
File "./lib/influxdb/__init__.py", line 9, in <module>
File "./lib/influxdb/client.py", line 19, in <module>
File "./lib/influxdb/line_protocol.py", line 12, in <module>
ImportError: No module named pytz
Any ideas of what could be causing this?
Mike
Sat Jan 19, 2019 12:19 pm
vtmikel offline
Re: Grafana install problem.
Interesting. Will investigate and get back to you.
Sat Jan 19, 2019 12:40 pm
pxzel offline
Wow. Thanks for the quick reply.
Sun Jan 20, 2019 1:08 pm
vtmikel offline
Hi- what Mac OSX version are you running?
Sun Jan 20, 2019 2:09 pm
pxzel offline
10.7.5
Sun Jan 20, 2019 2:18 pm
vtmikel offline
pxzel wrote:
10.7.5
I think you should be able to run the plugin, but it likely has to do with missing python libraries that I haven’t tested on your version of OS X.
Can you try the version I posted today?
Sun Jan 20, 2019 2:31 pm
pxzel offline
Cool! it installed and is providing me with config screen. Will mess with thus for the next hour. Thanks so much!
Sun Jan 20, 2019 3:34 pm
pxzel offline
Got half installed. Grafana server won't open.
Jan 20, 2019 2:32:30 PM
Grafana Home Dashboard first time setup -- config will now be created for InfluxDB. The InfluxDB server will restart a few times, once that is complete, Grafana will start.
Grafana Home Dashboard config file for InfluxDB has been updated; server will restart shortly.
Grafana Home Dashboard config file for Grafana has been updated; server will restart shortly.
Grafana Home Dashboard starting the InfluxDB Server...
Grafana Home Dashboard ######## InfluxDB server started. ########
Grafana Home Dashboard shutting down the InfluxDB Server...
Jan 20, 2019 2:34:10 PM
Grafana Home Dashboard ######## About to (re) start Grafana. Please be patient while this happens. ########
Grafana Home Dashboard starting the Grafana server...
Jan 20, 2019 2:34:25 PM
Grafana Home Dashboard Error error starting the Grafana server... will continue to attempt in the background
Jan 20, 2019 3:32:51 PM
Grafana Home Dashboard Error failed to start the Grafana server more than once, will not attempt again, please check your config
Tue Jan 22, 2019 11:09 am
pxzel offline
Should I do a separate install of Grafana for OS X?
Tue Jan 22, 2019 11:20 am
dduff617 offline
vtmikel can probably provide better info, but i'll just pass along that my first attempt at installing the 1.0.7 update produced repeated failures to start grafana that look (superficially) similar to what you are reporting. i stopped indigo server (not just the plugin) and then started the server again and things cleared up for me after that. your milage may vary, but maybe worth a try.
Tue Jan 22, 2019 11:56 am
pxzel offline
Thanks for input. I’ll try your suggestion. Thanks!
Tue Jan 22, 2019 8:40 pm
pxzel offline
Tried restarting a bunch of times. Grafana server doesn’t want to start. I’m halfway there. Influx server starts. Any ideas on the Grafana server not starting?
Tue Jan 22, 2019 8:47 pm
vtmikel offline
I glad you tried the restart, as it’s the easiest troubleshooting option. I’m guessing that your issue is related to the Grafana binary package on your version of OS X.
Sorry for the delay. I’ll respond tomorrow with a troubleshooting step I’ll need you to do.
Thu Jan 24, 2019 2:54 pm
vtmikel offline
My best guess is that the version of Grafana that I include in the plugin is not compatible with OS X 10.7, but we should find out for sure and I'll do my best to support it if I can.
Can you open a terminal window and run this command and send me the output. If you copy and paste it, it should work for your system.
/Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.2/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/grafana/grafana-server -homepath /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.2/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/grafana/ -config /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.2/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/grafana/conf/indigo.ini
Thu Jan 24, 2019 7:45 pm
pxzel offline
Output:
www:~ aaaa$ /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.2/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/grafana/grafana-server -homepath /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.2/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/grafana/ -config /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.2/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/grafana/conf/indigo.ini
Illegal instruction: 4
www:~ aaaa$
