Installing Grafana plugins to Grafana plugin
Sun Jun 17, 2018 1:16 pm
juntta offline
Smashing Topic Subject, don't you think? :D
I was wondering or more likely trialing and erroring is it possible to install Grafana plugins to Indigo Grafana plugin? I actually tried to install Ajax plugin (https://grafana.com/plugins/ryantxu-ajax-panel/installation) via command line command
grafana-cli plugins install ryantxu-ajax-panel
although this had to done in little longer form
/Library/Application\ Support/Perceptive\ Automation/Indigo\ 7/Plugins/Grafana\ Home\ Dashboard.indigoPlugin/Contents/Server\ Plugin/servers/grafana/grafana-cli plugins install ryantxu-ajax-panel
It however ended up to /usr/local/var/lib/grafana/plugins/ directory and it didn't load when I restarted Grafana so obviously that directory wasn't the right place. How these plugins should be installed or is it even possible? Maybe new feature to plugin to install plugins through the configuration panel...? ;)
Sun Jun 17, 2018 2:12 pm
vtmikel offline
Re: Installing Grafana plugins to Grafana plugin
Yeah... I've been meaning to address this.
What I recommend is to install manually via filesystem rather than the CLI, just because that's what I've done before and I'm not familiar with the CLI method.
Download the Grafana plugin manually, and put it here:
/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Grafana Home Dashboard.indigoPlugin/Contents/Server Plugin/servers/grafana/data/plugins
it should be a directory per plugin. See the current directory for an example, you'll find the Discrete plugin there.
In the future I'm going to move the plugins directory to something outside of the Indigo plugin bundle. For now, use this method but you'll have to re-install the Grafana plugin for each update to the Indigo Grafana Dashboard plugin (nice confusing set of words).
One you put the files in the plugin directory, restart the plugin.
Sun Jun 17, 2018 2:18 pm
vtmikel offline
Out of curiosity, what are you using the AJAX panel for?
Mon Jun 18, 2018 1:34 am
juntta offline
Thanks vtmikel, your instructions worked. I moved the plugin directory from
to
After that I used the "Rebuild and Restart" function from Grafana dashboard plugin menu in Indigo, waited for restart and it worked! :)
I'm planning to embed some weather widget from https://darksky.net/widgets to my dashboard and couldn't get those widgets working with text panel. So I saw example somewhere with embedded page in Grafana dashboard and that gave me idea... When I have something ready, I'll post a screenshot! :wink:
And many thanks for this great plugin, getting much better overall view to my system with Grafana dashboard
Sun Dec 02, 2018 5:35 pm
siclark offline
Hi. Did you get this working?
Mon Dec 03, 2018 1:34 am
juntta offline
If you meant Ajax Panel and embedding Dark Sky widget, I had some kind of draft version put together but some project with higher priority came up (probably wifes interior/garden project :)).
At least, there were some issues with refreshing after some idle time and positioning page. I check where I left off and post screenshot tonight when I get back home.
Mon Dec 03, 2018 8:02 am
vtmikel offline
I never finished looking into how I can move the Grafana plugins directory outside of the Indigo plugin bundle. Since I'm updating the plugin less frequently now, it's not as big of a pain to install to the plugin bundle, but I'll still put this on my list of things to do.
Mon Dec 03, 2018 1:01 pm
juntta offline
This is what I could find, I thought I had little more than this but I guess forgot to save at the end.... So basically I played with the darksky widget, saved it as html file and attached it to Grafana Dashboard with Ajax plugin.
Screenshot from edit mode
Mon Dec 03, 2018 2:59 pm
siclark offline
Thanks. I've found this setup that I'll try when I get a moment.
http://blog.mike-greene.com/adding-weat ... board/amp/
Mon Dec 03, 2018 10:16 pm
juntta offline
I found that one too, cant remember why I used the Ajax panel instead Text which Mike Greene uses on that blog. Maybe I try that approach as well when I get back to this one...
Tue Dec 04, 2018 10:26 am
siclark offline
I ended up going back to the AJAX plugin as well (once I RTFM and realised I needed to restart the plugin, not just Grafana after installing it!)
Also for anyone else wanting to use it,
take the http address after the src= and add to the URL
take the section after the ? and move to the Parameters section
delete the ?
replace
= with :
& with ,
put '' around all strings
for instance
embed:'true',
timeControl:'true',
fieldControl:'true',
defaultField:'radar'
I have added a bunch of Dark sky widgets and they even work on the fire 8, allowing me to change the type of map shown on below for example. Sadly the time drop downs dont work.
Screenshot 2018-12-04 at 16.08.13.png (498.92 KiB) Viewed 3811 times
