Should I be able to access InfluxDB via HTTP? I see some conflicting docs about this. Looking at the default configuration from the Grafana plugin's configuration dialog, it says "InfluxDB HTTP Port" = 8086, but if I use browser to attempt an HTTP connection on this port, I get a 404 error, which I think means there is an HTTP server there, but it doesn't like my (empty) path. Is there a a certain HTTP path I need to provide to expose basic access to Influx? Or is HTTP interface just for API access?
As far as "interactive" HTTP access, I see did stumble across some older references that say something to the effect that HTTP access to InfluxDB has been deprecated and replaced by another tool (?) called chronograf, however I'm not sure whether that is talking about the same thing...
I was looking to do some exploration of what's getting saved in InfluxDB - should I just use the command line interface to query?
