- Posted on
Mon May 14, 2018 12:22 pm
Different Computers
offline
Here's a start
- Code: Select all
Grafana Home Dashboard JSON representation of device Mike iPhone SE:
Grafana Home Dashboard subModel: (INCLUDED)
Grafana Home Dashboard protocol: 999.0 (NOT INCLUDED)
Grafana Home Dashboard state.MAC: a4:f1:e8:12:f1:1a (NOT INCLUDED)
Grafana Home Dashboard configured: True (NOT INCLUDED)
Grafana Home Dashboard address: a4:f1:e8:12:f1:1a (NOT INCLUDED)
Grafana Home Dashboard state.lastStatusChange: 2018-05-13 20:40:02 (NOT INCLUDED)
Grafana Home Dashboard displayStateValUi: up 05-13 20:40:02 (NOT INCLUDED)
Grafana Home Dashboard pluginId: com.karlwachs.uniFiAP (NOT INCLUDED)
Grafana Home Dashboard buttonGroupCount.num: 0.0 (NOT INCLUDED)
Grafana Home Dashboard measurement: device_changes (NOT INCLUDED)
Grafana Home Dashboard lastSuccessfulComm: 1526321672.0 (NOT INCLUDED)
Grafana Home Dashboard state.lastStatusChangeReason: MSG WiFi up (NOT INCLUDED)
Grafana Home Dashboard buttonGroupCount: 0.0 (NOT INCLUDED)
Grafana Home Dashboard state.powerMgmtWiFi: True (NOT INCLUDED)
Grafana Home Dashboard state.groupMember: Group0 (NOT INCLUDED)
Grafana Home Dashboard supportsAllOff: False (NOT INCLUDED)
Grafana Home Dashboard errorState: (NOT INCLUDED)
Grafana Home Dashboard state.upDownSetting: WiFi/Optimized-idle:180-exp:420 (NOT INCLUDED)
Grafana Home Dashboard configured.num: 1.0 (NOT INCLUDED)
Grafana Home Dashboard deviceTypeId: UniFi (INCLUDED)
Grafana Home Dashboard enabled.num: 1.0 (NOT INCLUDED)
Grafana Home Dashboard id: 453179804.0 (NOT INCLUDED)
Grafana Home Dashboard folderId: 960204446.0 (NOT INCLUDED)
Grafana Home Dashboard state.vendor: APPLE, INC. (NOT INCLUDED)
Grafana Home Dashboard displayStateId: displayStatus (NOT INCLUDED)
Grafana Home Dashboard state.noiseWiFi.num: -114.0 (NOT INCLUDED)
Grafana Home Dashboard displayStateImageSel: 601.0 (NOT INCLUDED)
Grafana Home Dashboard state.name: iPhone-SE (NOT INCLUDED)
Grafana Home Dashboard supportsStatusRequest: False (NOT INCLUDED)
Grafana Home Dashboard folderId.num: 960204446.0 (NOT INCLUDED)
Grafana Home Dashboard state.signalWiFi: -105 (NOT INCLUDED)
Grafana Home Dashboard state.signalWiFi.num: -105.0 (NOT INCLUDED)
Grafana Home Dashboard remoteDisplay.num: 0.0 (NOT INCLUDED)
Grafana Home Dashboard description: 192.168.0.017-Mikes-iPhone-SE=WiFi (NOT INCLUDED)
Grafana Home Dashboard id.num: 453179804.0 (NOT INCLUDED)
Grafana Home Dashboard supportsAllLightsOnOff.num: 0.0 (NOT INCLUDED)
Grafana Home Dashboard state.AP: 192.168.0.123-#0 (NOT INCLUDED)
Grafana Home Dashboard state.GHz.num: 2.0 (NOT INCLUDED)
Grafana Home Dashboard state.stateWiFi.num: 11111.0 (NOT INCLUDED)
Grafana Home Dashboard state.rx_tx_RateWiFi: 12000/65000 [Kb] (NOT INCLUDED)
Grafana Home Dashboard state.stateWiFi: 00011111 (NOT INCLUDED)
Grafana Home Dashboard state.noiseWiFi: -114 (NOT INCLUDED)
Grafana Home Dashboard state.status: up (NOT INCLUDED)
Grafana Home Dashboard name: Mike iPhone SE (NOT INCLUDED)
Grafana Home Dashboard supportsStatusRequest.num: 0.0 (NOT INCLUDED)
Grafana Home Dashboard lastChanged: 1526321672.0 (NOT INCLUDED)
Grafana Home Dashboard state.SW_Port: (NOT INCLUDED)
Grafana Home Dashboard state.GHz: 2 (NOT INCLUDED)
Grafana Home Dashboard enabled: True (NOT INCLUDED)
Grafana Home Dashboard state.ipNumber: 192.168.0.17 (NOT INCLUDED)
Grafana Home Dashboard supportsAllOff.num: 0.0 (NOT INCLUDED)
Grafana Home Dashboard remoteDisplay: False (NOT INCLUDED)
Grafana Home Dashboard supportsAllLightsOnOff: False (NOT INCLUDED)
Grafana Home Dashboard state.displayStatus: up 05-13 20:40:02 (NOT INCLUDED)
Grafana Home Dashboard displayStateValRaw: up 05-13 20:40:02 (NOT INCLUDED)
Grafana Home Dashboard state.created: 2016-10-07 14:31:19 (NOT INCLUDED)
Grafana Home Dashboard model: UniFi (INCLUDED)
Lots of "Not included" there. All I'm trying to do is show it as present/absent up/down whatever.
By data filters, do you mean excluded devices? I don't know what that is otherwise, so I'm pretty darn sure I haven't implemented them.
Doesn't seem to be much in the plugin log:
- Code: Select all
2018-05-14 14:20:12.304 DEBUG Plugin.checkServerStatus: completed checkServerStatus(), GrafanaServerStatus: started, InfluxServerStatus: started
2018-05-14 14:20:12.304 DEBUG Plugin.CheckInfluxAuthConfig: running CheckInfluxAuthConfig()
2018-05-14 14:20:12.305 DEBUG Plugin.CheckInfluxAuthConfig: now reviewing Influx config section: [meta]
2018-05-14 14:20:12.305 DEBUG Plugin.CheckInfluxAuthConfig: now reviewing Influx config section: [data]
2018-05-14 14:20:12.305 DEBUG Plugin.CheckInfluxAuthConfig: now reviewing Influx config section: [coordinator]
2018-05-14 14:20:12.306 DEBUG Plugin.CheckInfluxAuthConfig: now reviewing Influx config section: [retention]
2018-05-14 14:20:12.306 DEBUG Plugin.CheckInfluxAuthConfig: now reviewing Influx config section: [shard-precreation]
2018-05-14 14:20:12.306 DEBUG Plugin.CheckInfluxAuthConfig: now reviewing Influx config section: [monitor]
2018-05-14 14:20:12.306 DEBUG Plugin.CheckInfluxAuthConfig: now reviewing Influx config section: [subscriber]
2018-05-14 14:20:12.306 DEBUG Plugin.CheckInfluxAuthConfig: now reviewing Influx config section: [http]
2018-05-14 14:20:12.306 DEBUG Plugin.CheckInfluxAuthConfig: found that InfluxDB auth is enabled
2018-05-14 14:20:12.307 DEBUG Plugin.UpdateAll: running UpdateAll()
2018-05-14 14:20:13.400 DEBUG Plugin.UpdateAll: completed UpdateAll()
and more like that
