vtmikel wrote:Glad it worked out for you. I’m waiting for more feedback before I release it to the plugin store. Also I’d like to populate the wiki with sample queries.
ZachBenz wrote:Still haven't quite figured out how to get the render to actually function... but I will put up the promised pull request to see if others have better luck.
vtmikel wrote:ZachBenz wrote:Still haven't quite figured out how to get the render to actually function... but I will put up the promised pull request to see if others have better luck.
Happy to take a look when you are ready.
ZachBenz wrote:vtmikel wrote:ZachBenz wrote:Still haven't quite figured out how to get the render to actually function... but I will put up the promised pull request to see if others have better luck.
Pull request submitted!
vtmikel wrote:I checked my logs and found an error for rendering. A few google searches and I came across this: https://community.grafana.com/clicks/tr ... ic_id=6258
The version of Grafana I install is via Brew, so it looks like it's a known issue.
