"Image Downloader and SecuritySpy Helper Error"
Fri Jun 17, 2022 2:59 pm
shapa offline
Seeing identical errors with the new/latest version in two different environments (two homes).
" Image Downloader and SecuritySpy Helper Error Error in plugin execution ExecuteAction:
File "plugin.py", line 428, in downloadImage
File "plugin.py", line 139, in getImage
type: can only concatenate str (not "bytes") to str"
No images retrieved anymore.
Mon Jun 20, 2022 6:55 pm
agame offline
Re: "Image Downloader and SecuritySpy Helper Error"
i'm being prompted to upgrade this plugin but the link is broken:
https://www.indigodomo.com/pluginstore/162/release/1.8/
Mon Jun 20, 2022 7:13 pm
Where are you getting that URL?
In any event, you can just go to the plugin's page in the store and click the download button.
Mon Jun 20, 2022 7:15 pm
Never mind, now to figure out what's broken... :)
Mon Jun 20, 2022 7:49 pm
Ok, so the problem is that the developer isn't following the required pattern for naming releases. His latest release is tagged 1.8 in his github repo, but we require that release tags be X.Y.Z (must contain 3 numbers).
@vtmikel, if you're watching, you might want to delete your current 1.8 release and recreate it as 1.8.0 and it'll work correctly with the store and plugin update checks.
Mon Jun 20, 2022 8:00 pm
agame offline
i gather you figured it out (the landing page after following the Indigo 'Download New Version' menu).
Tue Jun 21, 2022 5:23 am
shapa offline
Any ideas on how to fix the bug? :)
Tue Jun 21, 2022 6:23 am
Did you install version 1.8? https://github.com/mlamoure/indigo-secu ... Plugin.zip
Tue Jun 21, 2022 9:47 am
shapa offline
Sure. The issue began with 1.8 - no problems with the older version (except old python and Intel only)
Tue Jun 21, 2022 10:11 am
Ah, sorry. confused the posters.
Yeah, that's a common Python2 to Python3 conversion error. Should be easy for the developer to fix.
Wed Jun 22, 2022 5:11 pm
vtmikel offline
OK. Did not realize that. I'll fix on next version
Sat Jun 25, 2022 7:29 am
vtmikel offline
I'll be posting an update to this plugin shortly. I've been testing some updates.
Sun Jun 26, 2022 8:03 am
shapa offline
Animated gif is not working :
"Image Downloader and SecuritySpy Helper Error Error in plugin execution ExecuteAction:
File "plugin.py", line 381, in downloadImage
type: can't concat str to bytes"
Sun Jun 26, 2022 8:24 am
vtmikel offline
Could you show me a screen shot of your Action Settings on the one that is throwing an error?
Mon Jun 27, 2022 10:00 am
shapa offline
Sure.
This is one that is not working (.gif) and working (.jpg)
Screenshot 2022-06-27 at 16.58.36.png (194.77 KiB) Viewed 1717 times
Screenshot 2022-06-27 at 16.57.55.png (181.99 KiB) Viewed 1717 times
