Stopping logs
Sat Mar 28, 2020 8:21 am
aderrington offline
Stopping logs
Is there a way to stop the following log entries?
Image Downloader and SecuritySpy Helper fetching image: http://xxxxxxxxxxxxxxx etc...
Personally i use it in a schedule every 5 seconds, so to see it in the logs is a little annoying....
Andrew
Sat Mar 28, 2020 9:14 am
vtmikel offline
Re: Stopping logs
Sure I can add. Out of curiosity are you doing that to embed into a control page?
Sat Mar 28, 2020 1:51 pm
vtmikel offline
Re: Stopping logs
I've posted a version on Github that will add an option to the action to suppress the logs.
Sun Mar 29, 2020 4:35 pm
aderrington offline
Re: Stopping logs
Thanks for that, I'll check it out tomorrow.
Yeah i'm querying my NVR for the image, Saving it to the mac and then several tablets retrieve the image every 4 seconds. I didn't want to tax the NVR to much so thought this was a better way.
Cheers!!
Mon Mar 30, 2020 3:56 am
aderrington offline
Re: Stopping logs
Thanks for the additional check box, Unfortunately it got rid of the original message but replaced it with the following:
Image Downloader and SecuritySpy Helper fetched image: xxxxxxxx  etc
Is there anything you can do to eliminate all but error messages from the log?
Thanks in advance!
Andrew
Tue Mar 31, 2020 11:06 am
vtmikel offline
Re: Stopping logs
I added the option in the Action Settings configuration to surpress the logs. Did you check the box? The default is not to suppress.
Wed Apr 01, 2020 7:25 am
aderrington offline
Re: Stopping logs
Yeah i did, It changed the logs from "fetching image" to "fetched Image" Although i think that was just in the update as when I check the box or uncheck the box it does the same thing and the logs remain. :(
Thank you for your help with this one!
Andrew
Wed Apr 01, 2020 10:04 am
vtmikel offline
Re: Stopping logs
Ok I think I discovered where I made an error. Try v1.6.3.
Tue Apr 07, 2020 12:17 pm
aderrington offline
Re: Stopping logs
Thank you for the fix! - Sorry it took so long to reply.
Works great now! Thank you for the very quick fix!
Great plugin!
