Problem with file location/name variable
Posted: Mon Oct 08, 2018 6:48 pm
This is working awesome with pushover thank you !
One problem I'm having...
If I select the USE A VARIABLE FOR DESTINATION LOCATION check box and then select a variable from the list I get the following events.
It looks like even though I specify the variable the plugin is still using /Users/myuser/Documents as the path.
If I uncheck the box and specify the path as /library/Application Support/Perceptive Automation/images/Cameras/PatioWalk.jpg then it works fine
Why would you have the ability to specify a variable for the destination and the URL but put the variables in a dropdown for the file location and use the %% notation for the URL
please help
Trigger GateWalkway Opened
Image Downloader and SecuritySpy Helper Error path does not exist: /Users/myuser/Documents
Pushover Debug Walkway Gate Opened
Pushover Debug Perimeter Alert
Pushover Debug /library/Application Support/Perceptive Automation/images/Cameras/PatioWalk.jpg
Pushover Debug Warning: file does not exist, or is not a jpeg file, attachment was skipped
thanks
Philip
please help
thanks
Philip
