url with passwords doesn't work for me
Wed Oct 03, 2018 8:16 pm
peszko offline
Hello,
I'm trying to access Hikvision NVR to get its camera's images. The URLs work in Indigo directly, but not through this plugin. I use the format:
http://username:password@nvrip/ISAPI/St ... 01/picture
This works when used in indigo in the refreshing image url controll, but I get a 401 with the plugin.
Any help appreciated.
Sat Oct 06, 2018 7:44 am
peszko offline
Re: url with passwords doesn't work for me
Hello,
Ok I fixed my problem. The issue is that my NVR was expecting digest authentication and this plugin doesn't support it.
So there are two solutions, turn off digest authentication or modify the plugin. Sine, I think digest is a better choice, I modified the plugin.
I changed the request as follows:
r = requests.get(url, stream=True, timeout=100, auth=HTTPDigestAuth(parsed.username, parsed.password))
You still need to import the HTTPDigestAuth
from requests.auth import HTTPDigestAuth
Possibly the author could add support for couple most used authentication methods.
Thanks.
Tue Oct 09, 2018 10:24 am
vtmikel offline
Thanks, I'll add this to my list to do.
Sun Nov 25, 2018 4:01 pm
vtmikel offline
Just to confirm, this is a general URL download and not SecuritySpy, correct? I dont think SecuritySpy supports Digest.
Wed Dec 26, 2018 9:35 am
peszko offline
Yes, this is the generic download from a Hikvision NVR. I have created my own plugin now to support the NVR directly. I didn't post it in the PluginStore, but if there is interest, I can. I'd just need to add some end user niceties such as version controll and better input checking.
