- Posted on
Wed Apr 24, 2019 8:27 am
vtmikel
offline
You’ll want to create a variable in Indigo for the image you want to save/refresh when the motion event occurs. Then, set up a trigger for the motion event. In the actions, have my plugin reach to SecuritySpy and get an image. If your cameras are set up in Indigo, this should be a simple thing to set up. Check the box to create a GIF, and you’ll likely want to limit the width of the image to reduce size. Select the amount of seconds to capture. Choose the variable you created to safe the GIF. Test it, make sure the resulting size is < 2.5MB.
Then, in your screenshot you attached, use the variable syntax %%v:VARIABLEID%%
Put your variable ID for the image location in there. Test the pushover notification.
Hope this helps.
