Cannot add lock device to Indigo
Fri Mar 15, 2019 9:58 am
justlen offline
Hello;
I am attempting to setup v1.0.16 of the August Plugin with a SmartLock Pro and Connect (not ZWave). I am able to authenticate with the server fine, but when attempting to add a device to Indigo it is not allowing me to select the installed lock.
Screenshot 2019-03-15 08.35.41.png (96.03 KiB) Viewed 1731 times
Screenshot 2019-03-15 08.36.41.png (95.89 KiB) Viewed 1731 times
Fri Mar 15, 2019 11:12 am
justlen offline
Re: Cannot add lock device to Indigo
Yes.
It authenticates correctly, but does not see any devices.
August Home Debug startup called
August Home Debug Completed processing activity logs
August Home Debug Obtaining a list of doorbells...
August Home Debug Response HTTP Status Code: 200
August Home Debug Response HTTP Response Body: {}
August Home Debug started variable updates
August Home Debug finished variable updates
August Home Debug Starting concurrent tread
Fri Mar 15, 2019 11:14 am
justlen offline
After about three reboots, it started seeing it.
Sun Mar 17, 2019 8:26 am
vtmikel offline
Sorry for delay. You are all set? Not sure why the API from August would take a few attempts to find your lock, but once it's there, it should be stable.
