Virtual Energy Meter
Sat Feb 24, 2018 1:18 pm
aldera offline
Re: Virtual Energy Meter
lindehoff wrote:
Hi, I am not at home at the moment. Will update the plugin as soon as possible.
That would be great! Thanks for responding!
Sat Feb 24, 2018 4:50 pm
siclark offline
I think this is exactly what I have been looking for to help understand my energy use. I was hoping to use this to monitor the consumption of my electric floors, where the thermostat, added via emaila plugin, records a heat on/off state. However none of my thermostat devices show up.
Would this be easy to change.
Mon Feb 26, 2018 6:42 am
lindehoff offline
I have now removed the Update checker and hopefully the plug in will work now.
I have tested it quickly and it works for me.
https://github.com/lindehoff/Indigo-VirtualEnergyMeter/releases/download/0.3.1/Virtual.Energy.Meter.indigoplugin.zip
Mon Feb 26, 2018 8:22 am
aldera offline
Seems to be working on my end. Thanks again for taking care of this. Great plugin!
Ralph
Wed Aug 17, 2022 5:41 am
Bildhauer offline
Hello,
is there an option to "urge" Virtual Energy Meter to update the power consumption (Energy Meter and Energy Meter current Power) using a Python Script?
Doing ti with following script
for dev in indigo.devices.iter("props.SupportsEnergyMeter"):
   if dev.enabled and dev.supportsStatusRequest and dev.model == "Virtual Group Energy Meter":
      indigo.device.statusRequest(dev)
it ends up in:
   Virtual Energy Meter Error      Error in plugin execution ServerReplacedElem:
  File "plugin.py", line 328, in deviceUpdated
KeyError: key id 710455184 not found in database
Best regards
Bildhauer
Tue Aug 23, 2022 2:26 pm
Bildhauer offline
If this plugin is not supported any more does anyone know a replacement?
Best regards
Bildhauer
Tue Aug 23, 2022 3:16 pm
howartp online
The error above is less a bug and more a missing device.
Have you checked/edited your plugin devices to make sure they're not pointing at/using a no-longer-existent device?
Sun Aug 28, 2022 2:54 pm
Bildhauer offline
I'll check but the Id which is shown i totally not known. So where ist it coming from?
